https://www.nxp.com/docs/en/data-sheet/MPX2202.pdf
I am trying to identify the gold thickness of the terminals, but it is not located on the datasheet.
Hello Matthew,
We have the material declaration for the sensor here https://www.nxp.com/mcds/MPXM2202A.pdf
Please let me know if this helps.
Paulina
Is the plating on the leads a part of the Copper Lead Frame section of materials?
The reasoning behind this request is for gold embrittlement concerns if the parts do not have the gold plating removed.
Hello Matthew,
Following your inquiry, I just received a response internally.
The MPXM2202A uses a pre-plated Lead Frame. The pre-plating material is NiPdAu (Nickel, Palladium, Gold), which substances are listed under the Copper Lead Frame material in the material declaration.
I hope this information can be helpful and we appreciate your patience.
Paulina
Hello Matthew,
I requested assistance internally in order to provide an accurate answer. I'll get back to you as soon as possible. Thank you for your patience.
Paulina
