What happens when the EN pin of TJA1043 is suspended?
The design is as follows:
TJA1043 EN ->MCU Output
We found that the TJA1043 EN could not communicate if the pin was pry open.
I checked the spec. EN high should be in listening - only mode.
So pin was pry open,does it work properly?
Solved! Go to Solution.
Hi Jingfang,
Both EN and STB_N pins are used to select operating mode of the transceiver. They have an internal pull-down, so the Standby mode is entered if these control pins are not driven upon "power on".
I hope it answers your question.
Tomas
Hi Jingfang,
Tomas
Hello~ The customer wants to know,under what circumstances will the EN pin work abnormally?Virtual welding is one of tem. What else?
