We are trying to access USBH1 .
We can use rel6. Could we download BSP rel6 ? If so, could you provide the link, if you know...
Please find below the details
mx31# /sbin/modprobe ehci_hcd port=h1
FATAL: Error inserting ehci_hcd (/lib/modules/2.6.19.2/kernel/drivers/usb/host/ehci-hcd.ko): Unknown symbol in module, or unknown parameter (see dmesg)
mx31# dmesg -c
ehci_hcd: Unknown symbol otg_get_transceiver
mx31#
***************Search for "otg_get_transceiver" in the kernel source
grep -irn "otg_get_transceiver" drivers/
Binary file drivers/usb/otg/fsl_otg.o matches
Binary file drivers/usb/otg/isp1504_arc.ko matches
drivers/usb/otg/fsl_otg.c:516: * after the udc driver's otg_get_transceiver() call
drivers/usb/otg/fsl_otg.c:702: struct otg_transceiver *otg_trans = otg_get_transceiver();
Binary file drivers/usb/otg/isp1504_arc.mod.o matches
drivers/usb/otg/isp1504_arc.mod.c:32: { 0xf610ed8c, "otg_get_transceiver" },
Binary file drivers/usb/otg/isp1504_arc.o matches
drivers/usb/host/ehci-hcd.mod.c:38: { 0xf610ed8c, "otg_get_transceiver" },
drivers/usb/host/ehci-arc.c:163: ehci->transceiver = otg_get_transceiver();
Binary file drivers/usb/host/ehci-hcd.o matches
drivers/usb/host/ohci-omap.c:210: ohci->transceiver = otg_get_transceiver();
Binary file drivers/usb/host/ehci-hcd.ko matches
Binary file drivers/usb/host/ehci-hcd.mod.o matches
Binary file drivers/usb/gadget/arcotg_udc.mod.o matches
drivers/usb/gadget/omap_udc.c:2749: xceiv = otg_get_transceiver();
Binary file drivers/usb/gadget/arcotg_udc.o matches
drivers/usb/gadget/arcotg_udc.c:2851: udc->transceiver = otg_get_transceiver();
drivers/usb/gadget/arcotg_udc.c:2852: pr_debug("udc: otg_get_transceiver returns 0x%p", udc->transceiver);
drivers/usb/gadget/arcotg_udc.mod.c:37: { 0xf610ed8c, "otg_get_transceiver" },
Binary file drivers/usb/gadget/arcotg_udc.ko matches
