We're Currently Using TEF6686 In Our Head Unit Design And Find The Initiate Code Sample In Datasheet Is Very Complicated. So We Want To Make Sure If There Are Sample Codes Available To Simplify Our Manual Code Jobs.
Currently We Use I.MX6 Quad As Host Controller And Run Android 7.1.1 Upon.
Hello Tomas
Thanks. We Have Got The Init Sample Codes.
Bright
Hi Bright,
Tuner devices like the TEF668x are made for a small part of the industry, therefore information, documentation, and support is limited. Unfortunately, I was not able to get the requested information, this request needs to come directly from your NXP Sales or Distributor FAE representative, so you should contact your NXP (or Distributor) Sales or FAE directly to get access to the requested sample codes.
Tomas
