did you generate PE code before building the project?
Use menu Project->Generate Processor Expert Code or click the icon on Component window.
BR, Petr
hi,
i found that problem, but after generating PE code,
there was still a error:
Ld error: cannot run program"": Launching failed C/C++ problem
i tried to reinstall S32DS, but there was an error: online license can not be deleted.
how to delete it?
thx
vic
not sure of teh error, can you share full log from S32DS?
BTW, tehre is new S32DS version 2.2. You can try to use that; https://community.nxp.com/docs/DOC-345517
BR, Petr
我也遇到了同样问题,后来发现是例程里面的generation文件夹里面的文件不能生成。我解决的办法是新添加PE,把报错的PE都添加进去。他们这个例程不知道是什么原因
你好,能留个联系方式吗,我重装了,还是不行,你的最后解决了吗?
