Profiling GPU on SBC-S32V234
ken3
I am trying to profile the GPU traffic through the DDRs using the sample GPU's codes available in the /opt/viv_samples/. I have the selected both cases for AXI_ID corresponding to GPU0 and GPU1 but do not see any read or write bytes value when I read the respective registers. Any hint if I am missing something or any other technical document other that the Reference Manual which would help understand this better. Thanks.
bpe
Please be informed, that all support to S32V234 and related software is done through tickets. If you wish NXP Technical Support to contact you with regards to the problem described in this post, please open a Support Case.
Platon
