PCA9685 parallel connection of output channels
545 次查看
azurkan
Hello there,
is it possible to connect two outputs of the PCA9685 to increase the maximum sink current in an open drain configuration? Of course both channels will get the same value settings.
I need to to sink about 45mA.
Thanks and regards,
Alex
503 次查看
guoweisun
Yes,you can do that!
Thanks!
