Matching network for MMG20241H
730 次查看
stefanomoscato
Dear all, I will embed the MMG20241H wideband driver in an RF high power board for LTE communications. I have issues to reproduce with the circuit simulator the EVB matching network for 1700-2100 MHz band.
I used the S2P parameter, the transmission lines are well dimensioned (as datasheet reports) and also the substrate set is the same of the EVB.
Do you have any suggestions?
Thanks in advance for your priceless time!
Stefano
  • RF
标记 (2)
627 次查看
andrei_skok
Please create a Service request for this issue.
How I could create a Service Request?
