In the MCUXpresso IDE, is there a way to draw in a window a data series ?
For example draw the content of an array graphically.
Luigi
Solved! Go to Solution.
Yes,
in MCUXpresso IDE, you can visualize a data series using the Peripherals+ view, Data Watchpoints and Tracing (DWT), or the FreeRTOS plugin for monitoring runtime data. For plotting, you can export Official Site data to a CSV file and use external tools like Excel or Python (with Matplotlib) to create the plot. This allows for flexible visualization of your data.
You can also use FreeMASTER to plot data very easily. It has built in data plotting.
Yes,
