I'm having a hard time configuring the LPUART0 in the device tree. I started using the imx8 boards recently and have difficulties understanding the clock assigning in the device node.
Does LPUART require an LPCG module? How do I know the clocks required by the LPUART? And the clock IDs in the clock specifier? Can you recommend me some documentation that I can read about?
Thank you, let me know if this isn't the correct forum to post this question.
Solved! Go to Solution.
You may use the definition we already have for LPUART0 as a reference, just please note that in our MEK board we use this port for debug output:
https://github.com/nxp-imx/linux-imx/blob/lf-6.6.y/arch/arm64/boot/dts/freescale/imx8-ss-dma.dtsi#L1...
https://github.com/nxp-imx/linux-imx/blob/lf-6.6.y/arch/arm64/boot/dts/freescale/imx8qm-mek.dts#L923
Also, regarding the forum, for i.MX processor questions I will suggest to use the following section:
https://community.nxp.com/t5/i-MX-Processors/bd-p/imx-processors
Best regards/Saludos,
Aldo.
Aldo.
