Capturing an iamge and Recording a video from Camera and Encoding Camera's O/P
5,767 次查看
nikhil29
Hello NXP
I'm working on a camera related project [ Using C Programming Only ] for that i need your help.
1]  to capture an image and record a video and then encode the same.
2]  after that i need to downscale that image and send to TV [ Host ].
So, to execute the above things could you please share some methods / tools / libraries / techniques to do the same.
Q1 : If i could use GStreamer, then i want to know the difference between how to capture / record    and  encode using GStreamer plugins  ??  [ Difference between record / capture and encode via GStreamer ]
Q2 : and for downscaling could i use OpenCV [ for C programming only ]  ??
If yes, then send me PDF / tools / libraries / methods realted to OpenCV
Nikhil
5,747 次查看
igorpadykov
Hi nikhil29
what processor used in the case. One can start with Chapter 6 Video
i.MX Linux Reference Manual​
Chapter 10 Unit Tests
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_5.4.24_2.1.0
Gstreamer examples in sect.7.3 Multimedia use cases i.MX Linux User’s Guide​
8 回复数
55 次查看
pocketorb12A
In Singapore, cabinet design services cater to individuals and businesses seeking customized storage solutions that blend functionality with aesthetic appeal. These services typically offer consultations to understand clients' needs, space constraints, and style preferences. Skilled designers utilize advanced software to create detailed 3D models, enabling clients to visualize the final product before construction begins. Cabinet design services in Singapore often emphasize quality craftsmanship, using premium materials that ensure durability and a polished finish. Whether for kitchens, offices, or retail spaces, these services strive to optimize storage efficiency while enhancing the overall look and feel of interiors, reflecting Singapore's commitment to functional elegance in home and commercial design.
1,137 次查看
tracyberge
No matter how long you have played, you will still not be able to accurately estimate the altitude of each takeoff. Therefore, any water pipe will be an extremely difficult challenge.  Flappy Bird
1,259 次查看
dalesmith657
Dark Dale is a Digital Marketer and blogger who ensures that a consistent important message is delivered to the user. He is detail-oriented and talented, allowing him to incorporate his digital & blogging skills with his vision to identify user needs and provide the best information to his readers. <a href=https://www.gotoassignmenthelp.com/blog/highly-effective-assignment-help-services-for-students/
1,518 次查看
Root76
Thanks for one marvelous posting! I enjoyed reading it; you are a great author.I will make sure to bookmark your blog and may come back someday. I want to encourage that you continue your great posts, have a nice weekend!
Disneyplus.com/begin
Disneyplus.com/start
5,748 次查看
igorpadykov
Hi nikhil29
5,713 次查看
nikhil29
Thanks igor for your time
I'm using i.MX 8M Plus as a processor.
1)  could you please ellaborate diff. between record/capture and encoding via GStreamer
2)  what about OpneCV  ??
nikhil
5,705 次查看
igorpadykov
Hi nikhil29
that processor is not supported yet, it is "Preproduction" part.
It will be supported after public launch.
5,698 次查看
nikhil29
Ok igor, thankuu for your time
Nikhil
