about NFC Antenna Pattern
798 次查看
theo-choi
The back of the NFC antenna pattern in the photo below is designed with a ground pattern. Could you advise on the characteristics this might entail?
Thank you.
732 次查看
Tomas_Parizek
Hello theo-choi
I know that some customers used similar patterns for better EMI behavior.
Tomas
4 回复数
733 次查看
Tomas_Parizek
Hello theo-choi
Tomas
748 次查看
KellyLi
Hello @theo-choi
Could you share the exact type of the IC what you are using? Maybe, some Demo design can be recommended to you for reference.
724 次查看
theo-choi
The chip in the above picture is an NXP chip, but it's not the one we use in our devices.
Thank you for your interest.
757 次查看
theo-choi
Connecting the center of the antenna pattern to GND improves the characteristics against power noise.
from 3ALogistics
