while I was developing my software on the OM27462CDK devboard the following error occurred:
LPCXpresso RedlinkMulti Driver v8.2 (Sep 5 2016 10:12:38 - crt_emu_cm_redlink build 725)
============= SCRIPT: PN7xxxxx_Connect.scp =============
DpID = 0BB11477
APID = 0x04770021
============= END SCRIPT ===============================
Probe Firmware: LPC-LINK2 CMSIS-DAP V5.173 (NXP Semiconductors)
Serial Number: JQD4BWMV
VID:PID: 1FC9:0090
USB Path: \\?\hid#vid_1fc9&pid_0090&mi_00#8&303495fc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
Cannot halt processor
Emu(0): Connected&Reset. DpID: 0BB11477. CpuID: 00000000. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Failed on chip setup: Ep(04). Cannot halt processor.
and:
Error in final launch sequence
Failed to execute MI command:
-target-select extended-remote | crt_emu_cm_redlink -msg-port=49519 -g -mi -2 -pPN7462AU-C3-00 -vendor=NXP -ConnectScript=PN7xxxxx_Connect.scp -ResetScript=PN7xxxxx_Reset.scp -reset= -ProbeHandle=1 -CoreIndex=0 -flash-driver=PN7xxxxx_158k.cfx
Error message from debugger back end:
Remote communication error. Target disconnected.: No error.
I did not touch the Board. I just changed some lines of code and clicked on debug.
After a while the debugging did not start anymore an above described message appears.
It looks to me like the MCU is broken?
Has somebody an Idea what's the reason and how to fix it?
Best Regards
Mario
解決済! 解決策の投稿を見る。
i solved the problem by replacing the PN7462.
Maybe not the smartest way but it solved the Problem
