What is the reason why the generated code don't have the main.c file ?
2,229 次查看
ChenBowen
Generate code,but there is no main.c file.   what is wrong?
2,200 次查看
SorinIBancila
Hello ChenBowen,
After you build the model, two folders are generated in the matlab's current location:
  • model_name_mbd_rtw;
  • slprj.
Inside the first folder ('model_name_mbd_rtw'), you are going to find the generated files. Here you are going to find the mbd_main.c.
Bancila Sorin
