S32K MBD-Toolbox generate code for IAR bug
1,129件の閲覧回数
cg0
Hello,I use matlab 2018b, And I generate code for IAR, I already install the patch.
After generate code, I import the code to IAR for more coding, also I select the "S32K14x.icf" as Linker file. But it always run into fault. Because before I choose the .icf file from matlab, and this situation can run normally.
So, I replace the .icf file, it do works. Then I compare the two .icf file. The matlab generated .icf alway use S32K148 256k flash.icf, no matter what MCU selected.
ラベル(2)
タグ(4)
3 返答(返信)
935件の閲覧回数
constantinrazva
Hello cg0‌,
Thank you for your investigation! We will make this fix and provide a patch in the S32K Hotfixes page, but we'll do so most probably in May, after the Holidays are over.
Kind regards,
Razvan.
935件の閲覧回数
cg0
Hi Razvan
As I know  from https://community.nxp.com/thread/484197, the next version will be released this Q2. Could you tell me will S32K116/118 be added in?
935件の閲覧回数
constantinrazva
Hello cg0‌,
Indeed, S32K116/118 will be added in our next release.
Kind regards,
Razvan.
