Model Reference Support - MPC57x
2,866 次查看
ext-rafael_barb
Does the Model Based Design toolbox support Model Referencing?
I am trying to build a simple example using Model Reference Block from Simulink, as you can see below:
But I am getting the following errors:
How can I build the model using model reference?
Kind Regards, Rafael Barbosa
17 回复数
2,337 次查看
Wensh
I am trying to have the configurations and interfaces of the peripherals in separate reference models, and the MCU configuration block in the model of Model, any hint on how I can achieve that?
2,325 次查看
mariuslucianand
Hello @Wensh ,
The MPC57xx toolbox uses a custom .tlc file based on the ert.tlc. For now, you have to add our configuration block to all of the referenced modes. Adding our configuration block should not affect the simulation at all. One way of keeping all the referenced models in sync with the top model is to save the Configuration for the top model and propagate it to the reference models.
Hope this helps,
Marius
2,298 次查看
Wensh
Yes it helped, will give a try, thank you.
2,347 次查看
Daniel_Popa
Hi ext-rafael.barbosa@chassisbrakes.com‌,
It is supported. Please have a look at the PIL example in the toolbox or here: https://community.nxp.com/thread/453726
You need to add a config block into the reference model too. (we currently working to remove this kind of limitation)
2,347 次查看
ext-rafael_barb
Hello dumitru-daniel.popa
Is there any news about these topics that I mentioned above?
2,350 次查看
ext-rafael_barb
Dear mariuslucianandrei‌,
Could you help me with this topic?
abhishek.kumar@chassisbrakes.com also is interested in the topic.
2,349 次查看
paulvlase
I am looking into your issue. I was able to reproduce your error, and I am trying to fix it. I will add a hotfix as soon as possible.
2,349 次查看
ext-rafael_barb
Dear paulvlase‌, mariuslucianandrei‌ and dumitru-daniel.popa
Do you have some updating regarding this topic?
Me and abhishekkumar@allgosystems.com are interested on this topic.
2,349 次查看
abhishek_kumar1
Dear paulvlase
As, ext-rafael.barbosa@chassisbrakes.com‌ mentioned. We are eagerly waiting for the hotfix you mentioned.
dumitru-daniel.popa‌, mariuslucianandrei
2,349 次查看
abhishek_kumar1
Dear paulvlase
Any news on this topic?
We are waiting for some solution as we want to work with segregation of Application part of the software.
mariuslucianandreidumitru-daniel.popa
2,349 次查看
mariuslucianand
Hello abhishek.kumar@chassisbrakes.com‌ and ext-rafael.barbosa@chassisbrakes.com‌,
We have investigated this and if we were to provide  a patch for adding support for the Reference Model, the patch would bring important changes to the toolbox structure. So we will try to add support for Reference Models in the next release, probably at the end of this year.
Also, if you have suggestions for features, feel free to express them.
Marius
2,349 次查看
abhishek_kumar1
Dear mariuslucianandrei‌, dumitru-daniel.popa
1. What would be the target date for next release?
2. Would you be able to provide a guideline (and support) to work with AUTOSAR in the next release?
Currently we can generate application code with AUTOSAR compliance but we fail to have base layer communication via RTE to application layer.
Abhishek
2,349 次查看
mariuslucianand
Hello abhishek.kumar@chassisbrakes.com‌,
For the first question, the release will be available probably in December this year. I will keep you updated regarding the date!
For the second one, we will enable support for the Matlab Autosar Blockset which will provide an easy way to test the AUTOSAR Application Layer directly on MPC57xx microcontrollers in PIL simulation. The same functionality which is already available for the S32K1xx in our toolboxes.
Marius
2,349 次查看
ext-rafael_barb
DearPaul Vlase, Marius-lucian Andrei and dumitru-daniel.popa
Also, could you provide me an alternative solution for the .elf file generation from multiple Simulink .slx files, via the combination of the generated C code generated separatelly?
2,349 次查看
ext-rafael_barb
Hi paulvlase‌,
Thank you.
Please let me know when you get news.
2,349 次查看
ext-rafael_barb
Hi again Daniel,
Regarding the PIL example, I could to run it here. However this example is different from what I am trying to do.
As you can see below, this model should just be executed and just the referenced block is build in the hardware.
In my current situation, I am trying to build the model with an inner referenced model.
And I can not do it.
Did you could build the model that I sent as example previously (inside ReferenceModelTest.zip) ?
2,349 次查看
ext-rafael_barb
Hi Daniel,
I added a configuration block in the referenced model as well, but I still could not build it.
When trying to build the above model, I got the following error message:
It is important to mention that I could build the referenced model "Sum" in the board, before used it as a reference model.
