MPC5675K Simulink code generation error
800件の閲覧回数
AsierMaser
Hi all,
I am working on a Simulink software and I am getting an error when generating the code. It is strange because both the compiler and the code generator advisor say that there is no error in the code, but the Matlab prompt shows an error message. This is what I get in the Matlab prompt:
As I have said, the compiler shows no error, but the code generator advisor  shows a warning. The warning is regarding the use of pulse generator blocks, and it is the only warning as you can see in the attached figure:
I also attach the config of the realtime workshop config page:
My system info:
Windows XP SP3 32 bits
Matlab R2010a
Motor Control Toolbox for MPC567xK
Any idea on what is happening here?
2 返答(返信)
756件の閲覧回数
SorinIBancila
Unfortunately the toolbox you are trying to use is deprecated and I am unable to properly provide support for it.
A suggestion I have for you is to consult the Motor_Control_Toolbox_Manual included in the toolbox and to make sure you followed all the steps required (Chapter 2.2 Installation Steps and 4. Required and Recommended Products).
Bancila Sorin
744件の閲覧回数
AsierMaser
We were able to solve the problem, now code generation works as expected.
