USB CDC virtual com example program on TWR70
839件の閲覧回数
sueneal
I am having problems running this example when I build the example for ddrdata.
If I build for sramdata then the USB enumerates correctly and I can run the example in windows 7
If I build the same program for ddrdata then the USB doesn't enumerate and windows 7 gives an error that the device is unknown.
I get numerous USB_APP_BUS_RESET events but never get the USB_APP_ENUM_COMPLETE event.
I've checked the linker files and the .usb_bdt is set in the sram data and aligned corectly in both linker files - the only difference between the two is the start address
Am running out of things to look for.
Any ideas would be appreciated.
タグ(1)
2 返答(返信)
572件の閲覧回数
isaacavila
Hello Sue,
Which example are you using? I was able to run cdc_vcom_twrk70f120m example that is located at: <MQX_4_2_PATH>/\usb\device\examples\cdc\virtual_com\build\cw10gcc and it worked well when ddrdata debug configuration was used.
Isaac Avila
572件の閲覧回数
sueneal
Hello Isaac,
I was using the kds build - I managed to get it working as I realised that my bsp had BSPCFG_HAS_SRAM_POOL and MQX_USE_UNCACHED_MEM turned off Once I turned them on it worked fine.
Sue
