I am using TWR-K20D72M and I opened a Sample program (Freescale\Freescale_MQX_4_0\mqx\examples\hello ) which is given in the MQX 4.0.1 Demo examples. When I choose Build tool option as Freescale
the program compiles OK but When I choose Build tool option as GCC It gives me error.The Error is below
error
Description | Resource | Path | Location | Type |
mingw32-make: *** No rule to make target `C:/Freescale/Freescale_MQX_4_0/lib/twrk20d72m.cw10gcc/debug/bsp/intflash.ld', needed by `explicit-dependencies'. | MQX_MODBUS_TEST1 | C/C++ Problem |
I read somewhere that The GCC can only work with MQX 4.0.1 and above so I am using MQX 4.0.1 .
Can some suggest me the reason for this error.How I can I remove this error.......
Hello yogesh patel,
what demo have you executed? Can you share console output?
How did you change compiler?
c0170
Hi martin
I am just executing the hello world example in the mqx example folder as shown in the picture below.
and the error is shown below in the picture.
You have to build MQX libraries for GCC compiler first, before an application. Drag and drop
c:\Freescale\Freescale_MQX_4_0\config\twrk20d72m\cw10gcc\twrk20d72m.wsd
into your Project window in CW 10.4 IDE and build the MQX libraries. At post built step, the linker command file will be copied from the bsp folder to the lib folder. Then build the example application.
Hi. I have opened this C:\Freescale\Freescale_MQX_4_0\config\twrk70f120m\cw10gcc\twrk20d72m.wsd
and I tried to compile BSP project. The result is a lot of warnings (117).
ignoring changed section attributes for .text | boot.S | /psp_twrk70f120m/PSP Cortex | line 52 | C/C++ Problem |
cast from pointer to integer of different size [-Wpointer-to-int-cast] | adt_kpdb.c | /bsp_twrk70f120m/Peripheral IO Drivers/adc/kadc | line 149 | C/C++ Problem |
conflicting types for built-in function '_exit' [enabled by default] | comp.c | /psp_twrk70f120m/PSP Cortex/compiler | line 43 | C/C++ Problem |
#pragma GCC target is not supported for this machine [-Wpragmas] | io_dopr.c | /psp_twrk70f120m/PSP Generic/fio | line 872 | C/C++ Problem |
floating constant exceeds range of 'double' [-Woverflow] floating constant exceeds range of 'double' [-Woverflow] | io_scanl.c | /psp_twrk70f120m/PSP Generic/fio | line 527 | C/C++ Problem |
cast to pointer from integer of different size [-Wint-to-pointer-cast] | timer_lpt.c | /bsp_twrk70f120m/Peripheral IO Drivers/timer | line 258 | C/C++ Problem |
'_ksai_sine_wave' declared 'static' but never defined [-Wunused-function] | sai_int_ksai.c | /bsp_twrk70f120m/Peripheral IO Drivers/sai/int | line 84 | C/C++ Problem |
How Can I solve this?
G.
warnings by MQX library build will be removed in next MQX version. For the moment, unless you make changes to the BSP source code, you may focus on your application.
Ok,
thanks.
So, I will wait MQX 4.1
In this moment I'm using MQX 4.0.2 + patch (FSLMQXOS_4_0_2_GA.exe + MQX_4.0.2.2_PATCH.zip)
Thanks again
Gionatha
