How to setup an interrupt stack in internal RAM of Coldfire MCF52277?
976件の閲覧回数
lumen
I would like to define an interrupt stack in the internal RAM with the following structure:
const MQX_INITIALIZATION_STRUCT  MQX_init_struct =
   /* PROCESSOR_NUMBER                */  BSP_DEFAULT_PROCESSOR_NUMBER,
   /* START_OF_KERNEL_MEMORY          */  BSP_DEFAULT_START_OF_KERNEL_MEMORY,
   /* END_OF_KERNEL_MEMORY            */  BSP_DEFAULT_END_OF_KERNEL_MEMORY,
   /* INTERRUPT_STACK_SIZE            */  BSP_DEFAULT_INTERRUPT_STACK_SIZE,
   /* TASK_TEMPLATE_LIST              */  MQX_template_list,
   /* MQX_HARDWARE_INTERRUPT_LEVEL_MAX*/  BSP_DEFAULT_MQX_HARDWARE_INTERRUPT_LEVEL_MAX,
   /* MAX_MSGPOOLS                    */  BSP_DEFAULT_MAX_MSGPOOLS,
   /* MAX_MSGQS                       */  BSP_DEFAULT_MAX_MSGQS,
   /* IO_CHANNEL                      */  BSP_DEFAULT_IO_CHANNEL,
   /* IO_OPEN_MODE                    */  BSP_DEFAULT_IO_OPEN_MODE,
   /* INTERRUPT_STACK_LOCATION        */  BSP_DEFAULT_INTERRUPT_STACK_LOCATION
In the linker file the interrupt stack is located as follows:
# interrupt stack
    interrupt_stack (RW) : ORIGIN = 0x80010000, LENGTH = 0x0000F800
    end_of_is        (RW) : ORIGIN = 0x8001F7FF, LENGTH = 0x00000000
Is this setup correct? MQX is starting up and the stack seems to be initialized, but the interrupts are not working correctly. I have tested my code with default interrupt stack (external RAM) and this is working.
What is missing? Is the init of MQX correct?
Patrick
788件の閲覧回数
lumen
There was another issue in the declaration of the interrupts. The MQX init above is working.
2 返答(返信)
789件の閲覧回数
lumen
788件の閲覧回数
RadekS
Thank you for your note.
