I am using S32DS working on MPC5748G.
Unable to debug now, display when erasing using the following tools:
Device IDcode is unknow
Device Revision is unknow
What is the matter, please?
Thanks and best regard,
lixu
Hi Lukaszadrapa
This is a new board. It is DEVKIT-MPC5748G.
I'm doing the simulation with USB Multilink, not OPENSDA.
So your method should not be applicable to this problem.
Looking forward your reply.
Hi Lixu,
was it working before that? If yes, what was the last operation?
If my understanding is correct, it's DEVKIT-MPC5748G, right? Have you confirmed the supply voltages are in expected range and that the reset line is not permanently tied to GND?
Sometimes it helps to update the OpenSDA:
Lukas
Hi Lukaszadrapa
