Problem in using UART+linflex in Mpc5606b
1,468 次查看
akhilmalik
hello sir,
i am using uart using linflex on mpc5606b in codewarrior
data is not being transmitted  ??
BELOW IS MY CODE
please reply ASAP
THANKYOU,,,
#include "MPC5606B.h"
void initModesAndClock(void);
void config_PORT_E(void);
void initPeriClkGen(void);
void init_LIN0(void);
void enableIrq(void);
void disableWatchdog(void);
int main (void) {
initModesAndClock(); /* Initialisation of the device */
config_PORT_E(); /* Configuration of GPIO */
initPeriClkGen();
LINFLEX_0.LINSR.B.DTF = 1;
SIU.GPDO[68].B.PDO=1;//for external 5V
enableIrq();
disableWatchdog();
init_LIN0();
for(;;)
  LINFLEX_0.BDRL.B.DATA0=0x11;
    LINFLEX_0.LINCR2.B.DTRQ = 1;
  while(LINFLEX_0.LINSR.B.DTF!=1){};
  SIU.GPDO[69].B.PDO=1;
SIU.PCR[68].R = 0x0200;
SIU.PCR[69].R = 0x0200;
SIU.PCR[18].R = 0x0604;//LIN_0TX
void initPeriClkGen(void) {
  CGM.SC_DC0.R=0x80;
void initModesAndClock(void) {
ME.MER.R = 0x0000001D;
ME.RUN[0].R = 0x001F0070;//16MHz
ME.RUNPC[0].R = 0x00000010;
ME.PCTL[68].R=0x00;
ME.PCTL[48].R=0x00;
ME.MCTL.R = 0x40005AF0;
ME.MCTL.R = 0x4000A50F;
while (ME.GS.B.S_MTRANS == 1) {}
while (ME.GS.B.S_CURRENTMODE != 4) {}
  LINFLEX_0.LINCR1.B.INIT = 1;
  while (0x1000 != (LINFLEX_0.LINSR.R & 0xF000)) {}
  LINFLEX_0.UARTCR.B.UART = 1;
  LINFLEX_0.LINCR1.B.LBKM = 1;
  LINFLEX_0.UARTCR.R = 0x00000011;
  LINFLEX_0.LINIBRR.B.DIV_M= 104; //Baud Rate @ 16MHZ = 9600
  LINFLEX_0.LINFBRR.B.DIV_F = 3;  //Baud Rate @ 16MHZ = 9600
void disableWatchdog(void) {
  SWT.SR.R = 0x0000c520;
  SWT.SR.R = 0x0000d928;
  SWT.CR.R = 0x8000010A;
  INTC.CPR.B.PRI=0;
  asm("wrteei 1");
943 次查看
akhilmalik
hi
it helped.
thanks :smileyhappy:
943 次查看
lukaszadrapa
attached you will find two working examples.
UART is also used in this example:
Example MPC5604B PinToggleStationery CW210
Lukas
