MPC5744 , is it possible to read vcc's real voltage through software layer ?
871 次查看
ChenBowen
Dear Expert:
       MPC5744P,  Can I  read the vcc's real voltage through software layer?
        By the way  ,  A Pressure sensor's formula is given as below:    P=5*adc_voltage-2.5    or   P=(adc_voltage/vcc)*25-2.5 ,   My ADC configuration is the same as you offered in S32DS example Projects.
The Pressure sensor's  later formula is more accurate as they said .
      Expert, my second question is , do I need to read the vcc voltage or simply consider it as 5V ?
867 次查看
davidtosenovjan
Do you mean VREFH? I don't see any meaning as it is always converted as 0xFFF as it defines converted range.
862 次查看
ChenBowen
Can I read vdd's voltage through software layer?
857 次查看
davidtosenovjan
No, but you can execute ADC selt-test as described here (what's use ADC reference and ADC supply voltage for these tests):
https://www.nxp.com/docs/en/application-note/AN5015.pdf
