Connect the radar signal to CAN_H and CAN_L pins on MPC5744P through the wire harness. Then, relevant modules in communication of MPC57XX MCUs in NXP Model-based Design Toolbox in Simulink were used for data analysis. Now, the problem is that only one target information of radar signal can be extracted, and multiple target information cannot be analyzed.
Could you be more specific? What is the setup you use? What radar chip is used?
How is the communication handled? There should be no issue in multiple CAN nodes. Or are you reffering to multiple targets detected by one AFE sensor?
Peter
