Can FEC memory be used as general-purpose RAM?
1,030 次查看
EAlepins
Contributor V
In the MPC5777C, I will not be using the FEC Ethernet controller. However, it would be nice if I could increase the total internal RAM such that the cores/applications could put variables in the FEC internal RAMs. Is that possible?
Also, what is the size and number of RAMs embedded in the FEC?
Thanks.
标记 (4)
909 次查看
davidtosenovjan
I have tried it and it seems FEC MIB RAM can be used as "normal" RAM when FEC is disabled. Is is small area 0xFFF4_C200h–0xFFF4_C3FFh and it can only be accessed by 32-bit. Also access time is expected to be slower (access over PBRIDGE).
FEC FIFO RAM does not seems to be possible to access directly.
910 次查看
davidtosenovjan
