CAN
CAN
542 次查看
bianwenchao
The CAN transmit pin of the MPC5744P is always high
539 次查看
PetrS
can you describe more info for your test? Do you run some NXP demo example on NXP board or what?
Generally, do you have FlexCAN TX/RX pins properly initialized? Are TX/RX pins connected to active transceiver on terminated bus? Do you see any error detected (see ESR/ECR registers)?
BR, Petr
