CAN Message RAM configuration
1,053件の閲覧回数
Noobie
I'm using MPC5777C controller.
In the data-sheet of the controller under memory map section, it is mentioned that M_CAN RAM is from 0xFFE3_4000 to 0xFFE3_7FFF. This I believe to be of 15.99KB.
But, under chip-specific M_CAN information it is mentioned that Message RAM supports 9.5KB.
May I know if M_CAN will support 15.99KB RAM or 9.5 KB ?
Thanks in advance.
2 返答(返信)
1,041件の閲覧回数
lukaszadrapa
Hi @Noobie
there's 9.5KB RAM only as mentioned in section 41.1.1.
The address range 0xFFE3_4000–0xFFE3_7FFF does not say that there's exactly the same amount of RAM. This range is used due to alignment.
Lukas
1,036件の閲覧回数
Noobie
Hello Lukas,
Thank you for the response.
Regards.
