LPC54016 - Missing ADC defines SDK 2.5.0
1,214 次查看
carl-circuitwor
After getting weird ADC readings with KSDK I found the ADC's were not being set up properly due to a few missing defines in LPC54016_features.h, also effects the 54018.
These are the missing defines I've found so far :
#define FSL_FEATURE_ADC_HAS_CTRL_RESOL (1)
#define FSL_FEATURE_ADC_HAS_CTRL_ASYNMODE (1)
#define FSL_FEATURE_ADC_HAS_CTRL_BYPASSCAL (1)
#define FSL_FEATURE_ADC_HAS_CTRL_TSAMP (1)
标记 (3)
1,090 次查看
ZhangJennie
Hi Carl,
I got reply from SDK development team.
New data will be included in SDK 2.6.0
Thanks for bringing the problem to our attention.
Jun Zhang
1,091 次查看
ZhangJennie
Hi Carl,
Jun Zhang
1,090 次查看
ZhangJennie
Hi Carl,
This problem was escalated and under discussion.
What is the impact on users?
What is the severity level of this problem? Thank you.
Jennie Zhang
1,090 次查看
ZhangJennie
Hi Carl.
I have escalated it to SDK developer. I will let you know if I get any response.
Jun Zhang
