What OS version are you using? It also looks like you may have changed the drive you installed the IDE onto from C: to D: correct?
Anyway, we've seen one similar case to this before with MCUXpresso IDE (though no reports with LPCXpresso IDE, which in this respect should be the same). That was solved by rebooting the PC...
