Sorry. I think I was not clear in my last message. What I meant to say was that I can't run the firmware out of the debugger, in stand alone.
Hi Marco,
What is the process you are following to run the program?
Can you debug without issues?
Soledad
Yes, Soledad
I'm able to run the code perfectly in debugger, but it doesn't run in stand alone.
Please see my reply on your other thread and let me know if it helps:
Can't run firmware on OM13092 in stand alone
Best Regards!Carlos MendozaTechnical Support Engineer
