Hello !
I can see in SDK examples you include standart C files as first ones and sometimes after all other #include.
Is any reason if location of those are not unified in SDK ?
Eugene
Hi Eugene:
Thank you for your feedback. The SDK examples were developed by many engineers , maybe many have their own coding style. The unified order will be better, I will forward your suggestion to the soft team.
For the include header file order, one rule is the headers not dependent upon other headers should be included first.
Hi Daniel !
Could it be provide script for apply code format style like in SDK ?
It have sense to follow it for have similar formatting in own code as well.
Eugene
Sorry I don't have this script for SDK. I would suggest you refer to following document.
Recommended C Style and Coding Standards
