AN12149 (Implementing IEEE 1588 PTP) using MCUXpresso
3,234 次查看
scottbrennan48
I am looking for a way to get AN12149 to build in MCUXpresso. In the AN12149.pdf document (page 11) it says that this app note is designed to compile on the IAR Embedded Workbench. I have downloaded IAR-EW and registered for a free 30 day trial. The app note builds successfully, but I would much rather work in MCUXpresso because it's what I am familiar with and it's free. Does anyone know of a way to restructure the project files for IAR-EW so that it works in MCUXpresso? So far all my attempts to do so have failed. Any help will be appreciated.
标记 (4)
2,959 次查看
xabiermarquiegu
Hello Scott,
I'm also interested in this. Did you make any progress?
If not, where can I find the original source code that works on the IAR Embedded Workbench?
3,207 次查看
ZhangJennie
Hi scottbrennan48
We don't have a doc generally about importing IAR project to MCUXpresso IDE. But I think this doc should help you. you can refer to the method of importing AN12103 for your work.
https://community.nxp.com/t5/i-MX-RT-Knowledge-Base/Migrating-AN12103-to-EVKB-MIMXRT1050-with-MCUXpr...
Have a nice day,
Jun Zhang
