Hello.
I want to measure BLE carrier signal, then develop phase-based ranging solution on MCUXpresso IDE.
What documentation or API should I reference? or any sample application?
Help me plz.
Solved! Go to Solution.
Hi, @zhengtan
As I know, firstly need your company to sign NDA with NXP.
And after that apply secure files access.
For signing NDA, please refer to: https://www.nxp.com/webapp-signup/ndaReqForm
For applying secure files access, please refer to: https://www.nxp.com/webapp-signup/updateDocstoreReg
The process might need some time to finish.
Christine.
Hi, @zhengtan
You can download our SDK from this link, please input KW45 to choose correct board
https://mcuxpresso.nxp.com/en/welcome
and will find this API guide: Bluetooth® Low Energy Host Stack API Reference Manual.pdf file located in:
SDK\docs\wireless\Bluetooth
Hope this info can help you somehow.
Christine.
Which example in the SDK has relevant content?
Hi, @zhengtan
Please check the available examples from our SDK for your reference.
Hope above info can help you somehow.
Christine.
My SDK doesn't have any of that.
Hi, @zhengtan
Which SDK are you using?
My SDK is:SDK_2_12_4_KW45B41Z-EVK
And also please check whether you can see this choice when you build SDK.
If you could not choose it or even can not see this choice, please contact the Distributor or our NXP Sales(Who/where do you buy our EVK) to ask permission access.
Christine.
I purchased directly from the Internet and have not received a reply for a long time. How do I get permission?
Hi, @zhengtan
Christine.
