LPC54102 CTIMER Capture Configuration
1,002 次查看
BTaylor
How can one use ConfigTools to configure input capture for a CTIMER? I cannot find anywhere in the tool where I can setup a capture input (channel, edge, etc.). Is this a case where I simply need to eschew the tool and configure things manually?
4 回复数
979 次查看
BTaylor
I understand now that ConfigTools does not support Counter mode. It also seems, though, that it does not fully support Capture/Match mode either. It allows match channels to be configured, but I do not see any way to configure capture channels.
974 次查看
ZhangJennie
Hi BTaylor
Match channel and capture channel are configured here: There are yellow  exclamation marks on the screenshot because the related pin is not routed. User needs to go to pin configuration tool to config the pin.
Have a nice day,
Jun Zhang
970 次查看
BTaylor
With which version of MXUXpresso (and ConfigTools) are you testing? The version I have does not have the 'Capture' section.
984 次查看
ZhangJennie
Hi BTaylor
Please refer answer in this thread
https://community.nxp.com/t5/MCUXpresso-Config-Tools/LPC54102-CTIMERx-in-Counter-Mode/td-p/1573949
Jun Zhang
