I have installed RDK-demo controller on my windows 10 laptop. But when ı try to run program, nothing happens. Program window does not open. In task manager, the task is running. I tried to run it as administrator, nothing has changed. Who can help me solving this issue?
Do you mean it can't be programmed? Or it doesn't run after programming?
You need to install the correct version of the matlab runtime environment and set the correct TFTP directory, then you can run app.exe normally.
