code warrior tap error
rashmikj
When i try to connect code warrior tap to LS1046ardb , I am getting the following error.
Kindly help
ufedor
Which Target Configuration is selected?
Run Diagnose Connection:
rashmikj
Please find attached error also when i scan for probe its unable to scan the codewarrior tap usb connected.
ufedor
Press "Connection Diagnostics" button and provide the Connection Diagnostics tab screenshot.
rashmikj
Please find attached screenshot.
ufedor
Please try the following steps:
1) completely uninstall CodeWarrior IDE
2) disable anti-virus application(s)
3) install latest Java
4) install CodeWarrior IDE
5) enable anti-virus application(s)
In case of further questions capture complete Help message as text.
rashmikj
After disabling the anti virus and reinstalling the code warrior , it is working fine.
Thank you.
