Using our board with LS1043 processor
567件の閲覧回数
carlos-m-ribeiro
Good morning,
If possible we would like to clarify a matter with NXP and we need your help.
In our company, we will have an real scenario that uses ls1043 processor in our boards. If we need only to use the U-BOOT for QSPI, the Frame Manager's (FMan), the Period and Pulse Accumulator (PPA) and the Reset Configuration Word (RCW), which should be the most recommended command ls1043aqds of flex-builder and which binaries should be flash into our board. Another important thing is to know which files are dedicated to our board.
3 返答(返信)
545件の閲覧回数
ufedor
PPA means Primary Protected Application. It is not supported for the LS1043A in the latest LSDK.
Considering requested functionality it will be supported by the composite firmware image generated by flexbuilder - please read the Layerscape Linux SDK Documentation:
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/layerscap...
542件の閲覧回数
carlos-m-ribeiro
Thank you for your response but there was a mistake. All we need for our board is the frame manager, U-BOOT and RCW+PBI=PBL.
559件の閲覧回数
carlos-m-ribeiro
NOTE: our board also need PBI-PBL.
