network time synchronization failed in LS1046A processor
rashmikj
In our custom board with LS1046A processor, after i generate mkbootpartition and port, I am getting this message
[FAILED] Failed to start Network Time Synchronization
[FAILED] Failed to start Network Name Resolution.
How do i resolve this?? Kindly help.
yipingwang
Please download the rootfs filesystem
wget https://www.nxp.com/lgfiles/sdk/lsdk2004/rootfs_lsdk2004_ubuntu_main_arm64.tgz
Please deploy images to SD card on your host.
$ flex-installer -b bootpartition_arm64_lts_5.4.tgz -r rootfs_lsdk2004_ubuntu_main_arm64.tgz -f firmware_ls1046ardb_uboot_sdboot.img -d /dev/sdx
rashmikj
I downloaded the images and deployed on SD Card.
The error still exists.
I deployed the same images on LS1046ardb  kit too. but the error is present. I have attached the log file.
yipingwang
I didn't reproduce your problem with LSDK 2004 pre-built images.
Please download prebuilt bootpartition and rootfs
wget https://www.nxp.com/lgfiles/sdk/lsdk2004/bootpartition_LS_arm64_lts_5.4.tgz
Please deploy images to SD card on your host, then test whether this problem exists on your target board.
$ flex-installer -b bootpartition_LS_arm64_lts_5.4.tgz -r rootfs_lsdk2004_ubuntu_main_arm64.tgz -d /dev/sdx
