Unusage SENSEVDD and SENSEVDDC pins on LS1046A
544 次查看
teo_kim
As I know SENSEVDD and SENSEGND pins pins are used by voltage regulator as feedback voltage for more fine voltage regulation "at the pin".
However, there is a question about not using these pins.
1. Is there no problem without using these pins?
2. If not in use, should it be no connection?
Please let me know.
Thank you.
Teo.
0 回复数
