I see that LX2160ARDB supports user-connected SATA devices.
Is SATA boot supported for:
Thank you,
Dmitri
已解决! 转到解答。
1. Firmware booted from SATA is not supported.
2. OS image loading from SATA by U-Boot is supported.
You could refer to the following procedure to deploy LSDK image to SATA disk.
1. Download lsdk2108_yocto_tiny_LS_arm64.itb and boot LX2160ARDB with this image.
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/lsdk2108_yocto_tiny_LS_arm64.itb
=> tftp 0xa0000000 nxa22585/lx2160ardb/lsdk2108_yocto_tiny_LS_arm64.itb
=> bootm 0xa0000000#lx2160ardb
2. In Linux OS on lx2160ardb
# flex-installer -i pf -d /dev/sdx (assume SATA device is /dev/sdx )
# mount /dev/sda4 /mnt
# cd /mnt
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/boot_LS_arm64_lts_5.10.tgz
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/rootfs_lsdk2108_ubuntu_main_arm64.tgz
# flex-installer -b boot_LS_arm64_lts_5.10.tgz -r rootfs_lsdk2108_ubuntu_main_arm64.tgz -d /dev/sdx
3. Under LSDK2108 u-boot, please run the following command to boot Linux from SATA.
=> run scsi_boot
# cd /mnt
=> run scsi_boot
Thank you for the answer.
I'm interested specifically in this command: run scsi_boot
I don't currently have LSDK2108 u-boot available on my board, can you please explain what run scsi_boot does exactly? I assume this is a script, which U-Boot commands does it execute?
Dmitri
