I have build net-snmp in ubantu 18.04.
./configure using cross compiler fsl-qoriql arrch64-fsl-linux-gnu, i am able to run service in ubuntu 18.04 successfully, but target machine is showing
./snmpd -d -f -L
warning: no access control information configured
[config search path: /ncs/etc/snmp:/ncs/share/snmp:/ncs/lib/snmp:/root/.snmp]
Run snmpconf -g basic-setup to help you configure the snmpd.conf file for this agent.
service is started but I am not able to get the agent response in client side here are the attached screenshots.
please help to get it sort it out.
Please run the following command to configure and generate snmpd.conf in /ncs/share/snmp
$cd /ncs
$ perl ./bin/snmpconf -i
Please refer to the following link to configure snmpd.conf file for the agent.
https://kb.juniper.net/InfoCenter/index?page=content&id=KB25949
Then run command
./sbin/snmpd -d -f -L
