DDR PHY: 1D training failed
2,015件の閲覧回数
muaxi8
Contributor V
I have downloaded the Flash DDR Fip Binary to the address XSPI Nor 0x800000.
When I connected to the LX2080A (LX2160A Family) using CodeWarrior, I received the following error:
What causes it and how can I fix it ?
My board‘’s uboot is now unable to get up, I guess that is the reason
Looking forward to reply
タグ(1)
6 返答(返信)
1,925件の閲覧回数
eneyland
I am having this issue as well, would like to know the solution others had to clear it.
2,005件の閲覧回数
ufedor
Which board is in question?
How DDR SDRAM is implemented?
Which code is debugged?
What are the steps required to replicate the issue?
1,990件の閲覧回数
muaxi8
Contributor V
Has been resolved
thanks!!
1,621件の閲覧回数
deepanrajanbara
Please let know , how the issue was resolved.
Thank you,
Deepanraj.A
1,946件の閲覧回数
xmj
I have met the similar issue.  Could you post the solution?
Thanks in advance!
1,982件の閲覧回数
ufedor
Could you please explain the issue cause and the cure?
