LS2088ARDB - How to deploy TF-A binaries in NOR flash
Trusted Firmware for Cortex-A (TF-A) is an implementation of EL3 secure firmware. TF-A replaces PPA in secure firmware role.
Please note the steps listed in this topic can only be performed with LSDK 18.12 and newer releases.
To migrate to the TF-A boot flow from the previous boot flow (with PPA), you need to compile the TF-A binaries, bl2_<boot_mode>.pbl and fip.bin, and flash these binaries on the specific boot medium on the board.
For NOR boot, you need to compile the following TF-A binaries.
TF-A binary nameComponents
bl2_nor.pbl
  • BL2 binary: Platform initialization binary
  • RCW binary for NOR boot
fip.bin
  • BL31: Secure runtime firmware
  • BL32: Trusted OS, for example, OPTEE (optional)
  • BL33: U-Boot/UEFI image
Follow these steps to compile and deploy TF-A  binaries (bl2_nor.pbl and fip.bin) on the NOR flash.
  1. Compile RCW binary
  2. Compile U-Boot binary
  3. [Optional] Compile OPTEE binary
  4. Compile TF-A binaries (bl2_nor.pbl and fip.bin) for NOR boot
  5. Program TF-A binaries to the NOR flash
Step 1: Compile RCW binary
You need to compile the rcw_1800.bin binary to build the bl2_nor.pbl binary.
Clone the  rcw repository and compile the PBL binary.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/rcw
  2. $ cd rcw
  3. $ git checkout -b <new branch name> <LSDK tag>. For example, $ git checkout -b LSDK-19.09 LSDK-19.09
  4. $ cd ls2088ardb
  5. If required, make changes to the rcw files.
  6. $ make
The compiled PBL binary for NOR boot on LS2088ARDB, rcw_1800.bin, is available at rcw/ls2088ardb/FFFFFFFF_PP_HH_0x2a_0x41
See the rcw/ls2088ardb/README file for an explanation of the naming convention for the directories that contain the RCW source and binary files.
Step 2: Compile U-Boot binary
You need to compile the u-boot.bin binary to build the fip.bin binary.
Clone the u-boot repository and compile the U-Boot binary for TF-A.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/u-boot.git
  2. $ cd u-boot
  3. $ git checkout -b <new branch name> LSDK-<LSDK version>. For example, $ git checkout -b LSDK-19.09 LSDK-19.09
  4. $ export ARCH=arm64
  5. $ export CROSS_COMPILE=aarch64-linux-gnu-
  6. $ make distclean
  7. $ make ls2088ardb_tfa_defconfig
  8. $ make
If the make command shows the error "*** Your GCC is older than 6.0 and is not supported", ensure that you are using Ubuntu 18.04 64-bit version for building the LSDK 18.12 and onwards U-Boot binary.
The compiled U-Boot binary, u-boot.bin, is available at u-boot/.
Step 3: [Optional] Compile OPTEE binary
You need to compile the tee.bin binary to build fip.bin with OPTEE. However, OPTEE is optional, you can skip the procedure to compile OPTEE if you want to build the FIP binary without OPTEE.
Clone the optee_os repository and build the OPTEE binary.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/optee_os
  2. $ cd optee_os
  6. $ make CFG_ARM64_core=y PLATFORM=ls-ls2088ardb
  7. $ aarch64-linux-gnu-objcopy -v -O binary out/arm-plat-ls/core/tee.elf out/arm-plat-ls/core/tee.bin
The compiled OPTEE image, tee.bin, is available at optee_os/out/arm-plat-ls/core/.
Step 4: Compile TF-A binaries for NOR boot
Clone the atf repository and compile the TF-A binaries, bl2_nor.pbl and fip.bin.
  1. $ git clone https://source.codeaurora.org/external/qoriq/qoriq-components/atf
  2. $ cd atf
  6. Build BL2 binary with OPTEE.
    • $ make PLAT=ls2088ardb bl2 SPD=opteed BOOT_MODE=nor BL32=<path_to_optee_binary>/tee.bin pbl RCW=<path_to_rcw_binary>/rcw_1800.bin
      The compiled BL2 images, bl2.bin and bl2_nor.pbl are available at atf/build/ls2088ardb/release/.
      For any update in the BL2 source code or RCW binary, the bl2_nor.pbl binary needs to be recompiled.
      To compile the BL2 binary without OPTEE:
      $ make PLAT=ls2088ardb bl2 BOOT_MODE=nor pbl RCW=<path_to_rcw_binary>/rcw_1800.bin
  7. Build FIP binary with OPTEE and without trusted board boot.
    • $ make PLAT=ls2088ardb fip BL33=<path_to_u-boot_binary>/u-boot.bin SPD=opteed BL32=<path_to_optee_binary>/tee.bin
      The compiled BL31 and FIP binaries, bl31.bin, fip.bin, are available at atf/build/ls2088ardb/release/.
      For any update in the BL31, BL32, or BL33 binaries, the fip.bin binary needs to be recompiled.
      To compile the FIP binary without OPTEE and without trusted board boot:
      $ make PLAT=ls2088ardb fip BOOT_MODE=nor BL33=<path_to_u-boot_binary>/u-boot.bin
      To compile the FIP binary with trusted board boot, refer the read me at <atf repository>/plat/nxp/README.TRUSTED_BOOT
Step 5: Program TF-A binaries to NOR flash
  1. Boot LS2088ARDB from NOR flash. Ensure that the switches and jumpers are set to boot the board from NOR bank 0.
    • SW5[1:8] = 1111 1111
    • SW3[1:8] = 0001 0010
    • SW4[1:8] = 1111 1111
    • SW6[1:8] = 1111 1111
    • SW7[1:8] = 0100 0010
    • SW9[1:8] = 0100 0000
    • SW8[1:8] = 0111 1111
  2. In addition to the above switch settings, make sure the following jumper settings are correct (for RDB Rev E and later)
    • J14 = 1-2, for NOR boot
  3. Boot from NOR bank 0: => qixis_reset
    For LS2088ARDB, in boot log, you'll see:
    Board: LS2088AE Rev1.1-RDB, Board Arch: V1, Board version: F, boot from vBank: 0
TF-A binaries can be loaded to LS2088ARDB from a TFTP server or from a mass storage device (SD, USB, or SATA).
Option 1: Load image from the TFTP server
Set up Ethernet connection
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
DPMAC1@xgmii, DPMAC2@xgmii, DPMAC3@xgmii, DPMAC4@xgmii, DPMAC5@xgmii, DPMAC6@xgmii, DPMAC7@xgmii, DPMAC8@xgmii
  1. Set server IP address to the IP address of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the Ethernet interface connected to the TFTP server.
    See LS2088ARDB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime DPMAC1@xgmii
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact DPMAC1@xgmii
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings. => saveenv
  5. Check the connection between the board and the TFTP server.
=> ping $serverip
Using DPMAC1@xgmii device
host 192.168.1.1 is alive
Load TF-A binaries from the TFTP server
For details about the flash image layout for TF-A binaries, refer LSDK memory layout for TF-A boot flow.
  1. Flash bl2_nor.pbl to NOR bank 4 (after booting from NOR bank 0).
    • => tftp 82000000 bl2_nor.pbl
    • => erase 0x584000000 +$filesize;cp.b 82000000 0x584000000 $filesize
  2. Flash fip.bin to NOR bank 4 (after booting from NOR bank 0).
    • => tftp 82000000 fip.bin
    • => erase 0x584100000 +$filesize;cp.b 82000000 0x584100000 $filesize
  3. Boot from NOR bank 4: => qixis_reset altbank
    LS2088ARDB will boot with TF-A. In the boot log, you will see:
    NOTICE: UDIMM 18ASF1G72AZ-2G3B1
    NOTICE: 16 GB DDR4, 64-bit, CL=13, ECC on, 256B, CS0+CS1
    NOTICE: 4 GB DDR4, 32-bit, CL=11, ECC on, CS0+CS1
    NOTICE: BL2: v1.5(release):LSDK-19.09
    NOTICE: BL2: Built : 16:04:08, Nov 4 2019
    NOTICE: BL31: v1.5(release):LSDK-19.09
    NOTICE: BL31: Built : 16:40:39, Nov 4 2019
    NOTICE: Welcome to LS2088 BL31 Phase
    U-Boot 2019.04 (Nov 04 2019 - 15:57:49 +0530)
    SoC: LS2088AE Rev1.1 (0x87090011)
    Clock Configuration:
    CPU0(A72):1800 MHz CPU1(A72):1800 MHz CPU2(A72):1800 MHz
    CPU3(A72):1800 MHz CPU4(A72):1800 MHz CPU5(A72):1800 MHz
    CPU6(A72):1800 MHz CPU7(A72):1800 MHz
    Bus: 700 MHz DDR: 1866.667 MT/s DP-DDR: 1600 MT/s
    Reset Configuration Word (RCW):
    00000000: 483038b8 48480048 00000000 00000000
    00000010: 00000000 00000000 00a00000 00000000
    00000020: 01e01180 00002581 00000000 00000000
    00000030: 00400c0b 00000000 00000000 00000000
    00000040: 00000000 00000000 00000000 00000000
    00000050: 00000000 00000000 00000000 00000000
    00000060: 00000000 00000000 00027000 00000000
    00000070: 412a0000 00040000
    Model: Freescale Layerscape 2080a RDB Board
    Board: LS2088AE Rev1.1-RDB, Board Arch: V1, Board version: F, boot from vBank: 4
Option 2: Load image from partition on mass storage device (SD, USB, or SATA)
  1. Select mass storage device to use.
    => mmc rescan
    => mmc info
    Or
    => usb start
    => usb info
    Or
    => scsi scan
    => scsi info
  2. Optional – List files on storage device
    => ls mmc <device:partition>
    For example:
    => ls mmc 0:2
    Or
    => ls usb <device:partition>
    For example:
    => ls usb 0:1
    Or
    => ls scsi <device:partition>
    For example:
    => ls scsi 0:2
    If the ls command fails to run, check that U-Boot in NOR bank 0 supports the command by typing ls at the U-Boot prompt:
    => ls ls - Lists files in a directory (default)
    Usage: ls <interface> [<dev[:part]> [directory]] - Lists files in directory [directory] of partition [part] on device type [interface] and instance [dev].
    If U-Boot does not support this command, then update the composite firmware image in NOR bank 0.
    For steps to update composite firmware image in NOR bank, see Layerscape Software Development Kit User Guide .
    Use the following command if the SD card is formatted/created using LSDK flex-installer command:
    => load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] For example:
    => load mmc 0:2 $load_addr bl2_nor.pbl Use the following command if the SD card is formatted/created on a Windows PC:
    => fatload <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] For example:
    => fatload mmc 0:2 $load_addr bl2_nor.pbl Use the following command if the SD card is formatted/created on a Linux PC:
    => ext2load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] For example:
    =>ext2load mmc 0:2 $load_addr bl2_nor.pbl Also note that LSDK flex-installer command puts the images on the IInd partition, so 0:2 is used in the load command. If the SD card is formatted on Windows PC or Linux PC for single partition only, then 0 should be used instead of 0:2 in the fatload/ext2load command.
  3. Load bl2_nor.pbl image from the storage device
    => load mmc 0:2 0xa0000000 <image name>
    => print filesize
    For example:
    => load mmc 0:2 0xa0000000 bl2_nor.pbl
    => print filesize
    filesize=14379
    Or
    => load usb 0:2 0xa0000000 <image name>
    => print filesize
    Or
    => load scsi 0:2 0xa0000000 <image name>
    => print filesize
  4. Program bl2_nor.pbl to NOR bank 4 (after booting from NOR bank 0): => erase 0x584000000 +$filesize;cp.b 0xa0000000 0x584000000 $filesize
  5. Load fip.bin image from the storage device
    => print filesize
    For example:
    => load mmc 0:2 0xa0000000 fip.bin
    => print filesize
    filesize=131510
    Or
    => print filesize
    Or
    => print filesize
  6. Program fip.bin to NOR bank 4 (after booting from NOR bank 0): => erase 0x584100000 +$filesize;cp.b 0xa0000000 0x584100000 $filesize
  7. Boot from NOR bank 4: => qixis_reset altbank
标签 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1118514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS2088ARDB%20-%20%E5%A6%82%E4%BD%95%E5%9C%A8%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%AD%E9%83%A8%E7%BD%B2%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECortex-A%20%E5%8F%AF%E4%BF%A1%E5%9B%BA%E4%BB%B6%20(TF-A)%20%E6%98%AF%20EL3%20%E5%AE%89%E5%85%A8%E5%9B%BA%E4%BB%B6%E7%9A%84%E4%B8%80%E4%B8%AA%E5%AE%9E%E7%8E%B0%E3%80%82TF-A%20%E5%9C%A8%E5%AE%89%E5%85%A8%E5%9B%BA%E4%BB%B6%E4%B8%AD%E5%8F%96%E4%BB%A3%E4%BA%86%20PPA%20%E7%9A%84%E8%A7%92%E8%89%B2%E3%80%82%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230f7198%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E6%9C%AC%E4%B8%BB%E9%A2%98%E4%B8%AD%E5%88%97%E5%87%BA%E7%9A%84%E6%AD%A5%E9%AA%A4%E5%8F%AA%E8%83%BD%E5%9C%A8%20%3CSPAN%3ELSDK%2018.12%20%E5%8F%8A%E6%9B%B4%E6%96%B0%E7%89%88%E6%9C%AC%E4%B8%AD%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3CP%3E%E8%A6%81%E4%BB%8E%E4%B9%8B%E5%89%8D%E7%9A%84%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%EF%BC%88%E5%B8%A6PPA%EF%BC%89%E8%BF%81%E7%A7%BB%E5%88%B0TF-A%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E7%BC%96%E8%AF%91TF-A%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_%3CBOOT_MODE%3E.%3C%2FBOOT_MODE%3E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Epbl%3C%2FSPAN%3E%E5%92%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%EF%BC%8C%E5%B9%B6%E5%B0%86%E8%BF%99%E4%BA%9B%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%88%B7%E5%86%99%E5%88%B0%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%E7%89%B9%E5%AE%9A%E5%90%AF%E5%8A%A8%E4%BB%8B%E8%B4%A8%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20NOR%20%E5%90%AF%E5%8A%A8%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E7%BC%96%E8%AF%91%E4%BB%A5%E4%B8%8B%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%20width%3A%2047.1046%25%3B%22%3E%3CTHEAD%3E%3CTR%20style%3D%22background-color%3A%20%23efefef%3B%20height%3A%2024px%3B%22%3E%3CTH%20style%3D%22width%3A%2023%25%3B%20height%3A%2024px%3B%22%3ETF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%90%8D%E7%A7%B0%3C%2FTH%3E%3CTH%20style%3D%22width%3A%2062.491%25%3B%20height%3A%2024px%3B%22%3E%E7%BB%84%E4%BB%B6%3C%2FTH%3E%3C%2FTR%3E%3C%2FTHEAD%3E%3CTBODY%3E%3CTR%20style%3D%22height%3A%2024px%3B%22%3E%3CTD%20style%3D%22height%3A%2024px%3B%20width%3A%2023%25%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22height%3A%2024px%3B%20width%3A%2062.491%25%3B%22%3E%3CUL%3E%3CLI%3EBL2%20%E4%BA%8C%E8%BF%9B%E5%88%B6%EF%BC%9A%E5%B9%B3%E5%8F%B0%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BA%8C%E8%BF%9B%E5%88%B6%3C%2FLI%3E%3CLI%3E%E7%94%A8%E4%BA%8E%20NOR%20%E5%90%AF%E5%8A%A8%E7%9A%84%20RCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FLI%3E%3C%2FUL%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22height%3A%2076px%3B%22%3E%3CTD%20style%3D%22height%3A%2076px%3B%20width%3A%2023%25%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22height%3A%2076px%3B%20width%3A%2062.491%25%3B%22%3E%3CUL%3E%3CLI%3EBL31%EF%BC%9A%E5%AE%89%E5%85%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E5%9B%BA%E4%BB%B6%3C%2FLI%3E%3CLI%3EBL32%EF%BC%9A%E5%8F%AF%E4%BF%A1%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%8C%E4%BE%8B%E5%A6%82OPTEE%EF%BC%88%E5%8F%AF%E9%80%89%EF%BC%89%3C%2FLI%3E%3CLI%3EBL33%EF%BC%9AU-Boot%2FUEFI%20%E9%95%9C%E5%83%8F%3C%2FLI%3E%3C%2FUL%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E5%9C%A8%20NOR%20%E9%97%AA%E5%AD%98%E4%B8%8A%E7%BC%96%E8%AF%91%E5%B9%B6%E9%83%A8%E7%BD%B2%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%88%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Epbl%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%20%E5%92%8C%20%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%EF%BC%89%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%E7%BC%96%E8%AF%91%20RCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FLI%3E%3CLI%3E%E7%BC%96%E8%AF%91%20U-Boot%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FLI%3E%3CLI%3E%5B%E5%8F%AF%E9%80%89%5D%20%E7%BC%96%E8%AF%91%20OPTEE%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FLI%3E%3CLI%3E%E7%BC%96%E8%AF%91%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Epbl%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%E7%94%A8%E4%BA%8E%20NOR%20%E5%90%AF%E5%8A%A8%3C%2FLI%3E%3CLI%3E%E5%B0%86%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%20NOR%20%E9%97%AA%E5%AD%98%3C%2FLI%3E%3C%2FOL%3E%3CH1%20id%3D%22toc-hId-381651664%22%20id%3D%22toc-hId-381651664%22%20id%3D%22toc-hId-1304247373%22%3E%E6%AD%A5%E9%AA%A4%201%EF%BC%9A%E7%BC%96%E8%AF%91%20RCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3CSPAN%20lang%3D%22EN-US%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%E6%82%A8%E9%9C%80%E8%A6%81%E7%BC%96%E8%AF%91%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw_1800.bin%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%9D%A5%E6%9E%84%E5%BB%BA%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%85%8B%E9%9A%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%3C%2FSPAN%3E%E4%BB%93%E5%BA%93%E5%B9%B6%E7%BC%96%E8%AF%91%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%E2%80%AFgit%20clone%26nbsp%3B%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Frcw%3C%2FA%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3Ecd%20rcw%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20git%20checkout%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CLSDK%20tag%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20%E4%BE%8B%E5%A6%82%EF%BC%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20git%20checkout%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%20LSDK-19.09%3C%2FSPAN%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%26nbsp%3Bcd%20ls2088ardb%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E8%AF%B7%E5%AF%B9%20rcw%20%E6%96%87%E4%BB%B6%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%94%B9%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%24%20make%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%94%A8%E4%BA%8E%3CSPAN%3ELS2088ARDB%20NOR%20%E5%90%AF%E5%8A%A8%E7%9A%84%E5%B7%B2%E7%BC%96%E8%AF%91%20PBL%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw_1800.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%8F%AF%E5%9C%A8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%3C%2FSPAN%3E%20%3CSPAN%20data-ccp-props%3D%22%7B%22%20201341983%3D%22%22%3E%2Fls2088ardb%2FFFFFFFFF_PP_HH_0x2a_0x41%3C%2FSPAN%3E%E4%B8%AD%E6%89%BE%E5%88%B0%3C%2FP%3E%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20_modifiedtitle%3D%22true%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E6%9C%89%E5%85%B3%E5%8C%85%E5%90%AB%20RCW%20%E6%BA%90%E6%96%87%E4%BB%B6%E5%92%8C%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E7%9B%AE%E5%BD%95%E7%9A%84%E5%91%BD%E5%90%8D%E7%BA%A6%E5%AE%9A%E7%9A%84%E8%AF%B4%E6%98%8E%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ercw%2Fls2088ardb%2FREADME%3C%2FSPAN%3E%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FPRE%3E%3C%2FPRE%3E%3CH1%20id%3D%22toc-hId--1425802799%22%20style%3D%22font-weight%3A%20bold%3B%20font-size%3A%2024px%3B%22%20id%3D%22toc-hId--1425802799%22%20id%3D%22toc-hId--503207090%22%3E%E6%AD%A5%E9%AA%A4%202%EF%BC%9A%E7%BC%96%E8%AF%91%20U-Boot%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FH1%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E6%82%A8%E9%9C%80%E8%A6%81%E7%BC%96%E8%AF%91%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot.bin%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%BB%A5%E6%9E%84%E5%BB%BA%26nbsp%3B%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E5%85%8B%E9%9A%86%20%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Eu-boot%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%20%3C%2FSPAN%3E%E4%BB%93%E5%BA%93%EF%BC%8C%E5%B9%B6%E4%B8%BA%20TF-A%20%E7%BC%96%E8%AF%91%20U-Boot%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%E2%80%AFgit%20clone%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CA%20data-content-finding%3D%22Community%22%20style%3D%22color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20inherit%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Fu-boot.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Ecd%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Eu-boot%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20g%3C%2FSPAN%3E%20it%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20g%3C%2FSPAN%3E%20it%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E5%AF%BC%E5%87%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EARCH%3Darm64%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20%E5%AF%BC%E5%87%BA%20CROSS_COMPILE%3D%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Eaarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20make%20%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Edistclean%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20ls2088ardb_tfa_defconfig%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E5%88%B6%E4%BD%9C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CPRE%20___default_attr%3D%22info%22%20_alert%3D%22info%22%20_modifiedtitle%3D%22true%22%20jivemacro%3D%22alert%22%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E5%A6%82%E6%9E%9C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%3C%2FSPAN%3E%E5%91%BD%E4%BB%A4%E6%98%BE%E7%A4%BA%E9%94%99%E8%AF%AF%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E2%80%9C***%20%E6%82%A8%E7%9A%84%20GCC%20%E7%89%88%E6%9C%AC%E6%97%A9%E4%BA%8E%206.0%20%E5%B9%B6%E4%B8%94%E4%B8%8D%E5%8F%97%E6%94%AF%E6%8C%81%E2%80%9D%3C%2FSPAN%3E%20%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E6%82%A8%E4%BD%BF%E7%94%A8%20Ubuntu%2018.04%2064%20%E4%BD%8D%E7%89%88%E6%9C%AC%E6%9D%A5%E6%9E%84%E5%BB%BA%20LSDK%2018.12%20%E5%8F%8A%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%E7%9A%84%20U-Boot%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FPRE%3E%3C%2FPRE%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E7%BC%96%E8%AF%91%E5%90%8E%E7%9A%84%20U-Boot%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%EF%BC%8C%E5%8F%AF%E5%9C%A8%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eu-boot%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%E7%9B%AE%E5%BD%95%E4%B8%AD%E6%89%BE%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId-1061710034%22%20style%3D%22border%3A%200px%3B%22%20id%3D%22toc-hId-1061710034%22%20id%3D%22toc-hId-1984305743%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E7%AC%AC%E4%B8%89%E6%AD%A5%EF%BC%9A%5B%E5%8F%AF%E9%80%89%5D%E7%BC%96%E8%AF%91OPTEE%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E8%A6%81%E4%BD%BF%E7%94%A8OPTEE%E7%94%9F%E6%88%90%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFIP.bin%3C%2FSPAN%3E%EF%BC%8C%26nbsp%3B%E6%82%A8%E9%9C%80%E8%A6%81%E7%BC%96%E8%AF%91%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Etee.bin%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E6%A1%A3%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8COPTEE%E6%98%AF%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%8C%3C%2FSPAN%3E%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8OPTEE%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%BC%96%E8%AF%91FIP%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E6%A1%A3%3C%2FSPAN%3E%EF%BC%8C%26nbsp%3B%E5%8F%AF%E4%BB%A5%E8%B7%B3%E8%BF%87%E7%BC%96%E8%AF%91OPTEE%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%85%8B%E9%9A%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eoptee_os%3C%2FSPAN%3E%E5%AD%98%E5%82%A8%E5%BA%93%E5%B9%B6%E6%9E%84%E5%BB%BAOPTEE%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Egit%20clone%20%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Foptee_os%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecd%20optee_os%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.0pt%3B%22%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-.%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%24%20export%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%20ARCH%3Darm%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20data-ccp-props%3D%22%7B%22%20134233279%3D%22%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%20CROSS_COMPILE%3Daarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Emake%20CFG_ARM64_core%3Dy%20%E5%B9%B3%E5%8F%B0%3Dls-ls2088ardb%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eaarch64-linux-gnu-objcopy%20-v%20-O%20binary%20out%2Farm-plat-ls%2Fcore%2Ftee.elf%20out%2Farm-plat-ls%2Fcore%2Ftee.bin%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E7%BC%96%E8%AF%91%E5%90%8E%E7%9A%84OPTEE%E9%95%9C%E5%83%8F%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Etee.bin%3C%2FSPAN%3E%E5%8F%AF%E5%9C%A8%26nbsp%3B%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eoptee_os%2Fout%2Farm-plat-ls%2Fcore%2F%3C%2FSPAN%3E%E5%A4%84%E8%8E%B7%E5%8F%96%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--745744429%22%20id%3D%22toc-hId--745744429%22%20id%3D%22toc-hId-176851280%22%3E%E6%AD%A5%E9%AA%A4%204%EF%BC%9A%E7%BC%96%E8%AF%91%E7%94%A8%E4%BA%8E%20NOR%20%E5%90%AF%E5%8A%A8%E7%9A%84%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FH1%3E%3CP%3E%3CSPAN%3E%E5%85%8B%E9%9A%86%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eatf%3C%2FSPAN%3E%20%E4%BB%93%E5%BA%93%E5%B9%B6%E7%BC%96%E8%AF%91%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%8C%85%E6%8B%AC%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Epbl%3C%2FSPAN%3E%3CSPAN%3E%20%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Egit%20clone%20%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fsource.codeaurora.org%2Fexternal%2Fqoriq%2Fqoriq-components%2Fatf%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecd%20atf%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%3CNEW%20branch%3D%22%22%20name%3D%22%22%3E%3C%2FNEW%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20LSDK-.%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20%24%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20git%20checkout%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%20-b%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20LSDK-19.09%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%26nbsp%3BARCH%3Darm64%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eexport%20CROSS_COMPILE%3Daarch64-linux-gnu-%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EBuild%20BL2%20binary%20with%20OPTEE.%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E%24%20make%20PLAT%3Dls2088ardb%20bl2%20SPD%3Dopteed%20BOOT_MODE%3Dnor%20BL32%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_OPTEE_BINARY%3E%2F%3C%2FPATH_TO_OPTEE_BINARY%3E%3C%2FSPAN%3Etee.bin%20pbl%20RCW%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_RCW_BINARY%3E%3C%2FPATH_TO_RCW_BINARY%3E%3C%2FSPAN%3E%2Frcw_1800.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E7%BC%96%E8%AF%91%E5%90%8E%E7%9A%84%20BL2%20%E6%98%A0%E5%83%8F%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2.bin%3C%2FSPAN%3E%E5%92%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%E5%8F%AF%E5%9C%A8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eatf%2Fbuild%2Fls2088ardb%2Frelease%2F%3C%2FSPAN%3E%E5%A4%84%E8%8E%B7%E5%BE%97%E3%80%82%3C%2FP%3E%E5%AF%B9%E4%BA%8E%20BL2%20%E6%BA%90%E4%BB%A3%E7%A0%81%E6%88%96%20RCW%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%96%B0%EF%BC%8C%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%E3%80%82%3C%2FSPAN%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E5%9C%A8%E6%B2%A1%E6%9C%89OPTEE%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%BC%96%E8%AF%91BL2%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%24%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3Emake%20PLAT%3Dls2088ardb%20bl2%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3EBOOT_MODE%3Dnor%20pbl%20RCW%3D%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3E%3CPATH_TO_RCW_BINARY%3E%2F%3C%2FPATH_TO_RCW_BINARY%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3Ercw_1800.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%20%20%20%20%20%20%20%3C%2FPRE%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8OPTEE%E6%9E%84%E5%BB%BAFIP%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%26nbsp%3B%EF%BC%8C%E6%97%A0%E9%9C%80%E5%8F%AF%E4%BF%A1%E6%9D%BF%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FSTRONG%3E%3CUL%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E%24%20make%20PLAT%3Dls2088ardb%20fip%20BL33%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_U-BOOT_BINARY%3E%3C%2FPATH_TO_U-BOOT_BINARY%3E%3C%2FSPAN%3E%2Fu-boot.bin%20SPD%3Dopteed%20BL32%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_OPTEE_BINARY%3E%3C%2FPATH_TO_OPTEE_BINARY%3E%3C%2FSPAN%3E%2Ftee.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%E5%B7%B2%E7%BC%96%E8%AF%91%E7%9A%84%20BL31%20%E5%92%8C%20FIP%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl31.bin%3C%2FSPAN%3E%20%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3Efip%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%8F%AF%E5%9C%A8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eatf%2Fbuild%2Fls2088ardb%2Frelease%2F%3C%2FSPAN%3E%E5%A4%84%E6%89%BE%E5%88%B0%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E5%AF%B9%E4%BA%8E%20BL31%E3%80%81BL32%20%E6%88%96%20BL33%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%96%B0%EF%BC%8C%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%20fip.bin%3C%2FSPAN%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E8%A6%81%E7%BC%96%E8%AF%91%E4%B8%8D%E5%8C%85%E5%90%ABOPTEE%E4%B8%94%E4%B8%8D%E4%BE%9D%E8%B5%96%E5%8F%AF%E4%BF%A1%E6%9D%BF%E5%90%AF%E5%8A%A8%E7%9A%84FIP%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%9A%0A%0A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%24%20make%20PLAT%3Dls2088ardb%20fip%20BOOT_MODE%3Dnor%20BL33%3D%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CPATH_TO_U-BOOT_BINARY%3E%2F%3C%2FPATH_TO_U-BOOT_BINARY%3E%3C%2FSPAN%3Eu-boot.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A6%81%E7%BC%96%E8%AF%91%E5%B8%A6%E6%9C%89%E5%8F%AF%E4%BF%A1%E6%9D%BF%E5%90%AF%E5%8A%A8%E7%9A%84%20FIP%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CATF%20repository%3D%22%22%3E%2Fplat%2Fnxp%2FREADME.TRUSTED_BOOT%3C%2FATF%3E%3C%2FSPAN%3E%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FPRE%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CH1%20id%3D%22toc-hId-1741768404%22%20id%3D%22toc-hId-1741768404%22%20id%3D%22toc-hId--1630603183%22%3E%E6%AD%A5%E9%AA%A4%205%EF%BC%9A%E5%B0%86%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%20NOR%20%E9%97%AA%E5%AD%98%3C%2FH1%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%E5%BC%95%E5%AF%BC%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%9D%A5%E8%87%AA%20NOR%20%E9%97%AA%E5%AD%98%E7%9A%84%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3ELS2088ARDB%3C%2FSPAN%3E%20%E3%80%82%E7%A1%AE%E4%BF%9D%E5%BC%80%E5%85%B3%E5%92%8C%E8%B7%B3%E7%BA%BF%E8%AE%BE%E7%BD%AE%E4%B8%BA%E4%BB%8E%20NOR%20%E7%BB%84%200%20%E5%90%AF%E5%8A%A8%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FSPAN%3E%3CUL%3E%3CLI%3ESW5%5B1%3A8%5D%20%3D%201111%201111%3C%2FLI%3E%3CLI%3ESW3%5B1%3A8%5D%20%3D%200001%200010%3C%2FLI%3E%3CLI%3ESW4%5B1%3A8%5D%20%3D%201111%201111%3C%2FLI%3E%3CLI%3ESW6%5B1%3A8%5D%20%3D%201111%201111%3C%2FLI%3E%3CLI%3ESW7%5B1%3A8%5D%20%3D%200100%200010%3C%2FLI%3E%3CLI%3ESW9%5B1%3A8%5D%20%3D%200100%200000%3C%2FLI%3E%3CLI%3ESW8%5B1%3A8%5D%20%3D%200111%201111%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E9%99%A4%E4%BA%86%E4%B8%8A%E8%BF%B0%E5%BC%80%E5%85%B3%E8%AE%BE%E7%BD%AE%E5%A4%96%EF%BC%8C%E8%AF%B7%E7%A1%AE%E4%BF%9D%E4%BB%A5%E4%B8%8B%E8%B7%B3%E7%BA%BF%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%88%E9%80%82%E7%94%A8%E4%BA%8E%20RDB%20Rev%20E%20%E5%8F%8A%E6%9B%B4%E9%AB%98%E7%89%88%E6%9C%AC%EF%BC%89%3C%2FSPAN%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EJ14%20%3D%201-2%EF%BC%8C%E7%94%A8%E4%BA%8ENOR%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E4%BB%8E%3CSPAN%3ENOR%20bank%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E0%20%E5%90%AF%E5%8A%A8%EF%BC%9A%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20qixis_reset%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%E5%AF%B9%E4%BA%8E%20LS2088ARDB%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS2088AE%20Rev1.1-RDB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AF%EF%BC%8C%E4%BB%8E%20vBank%20%E5%90%AF%E5%8A%A8%EF%BC%9A0%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%2351626f%3B%22%3ETF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%8F%AF%E4%BB%A5%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E6%88%96%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%EF%BC%88SD%E3%80%81USB%20%E6%88%96%20SATA%EF%BC%89%E5%8A%A0%E8%BD%BD%E5%88%B0%20LS2088ARDB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1862637418%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--1862637418%22%20id%3D%22toc-hId--940041709%22%3E%E9%80%89%E9%A1%B9%201%EF%BC%9A%E4%BB%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BD%E5%9B%BE%E5%83%8F%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1172075944%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--1172075944%22%20id%3D%22toc-hId--249480235%22%3E%E8%AE%BE%E7%BD%AE%E4%BB%A5%E5%A4%AA%E7%BD%91%E8%BF%9E%E6%8E%A5%3C%2FH3%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22border%3A%200px%3B%22%3E%E4%B8%BB%E6%9D%BF%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8CU-Boot%20%E4%BC%9A%E6%89%93%E5%8D%B0%E5%87%BA%E5%B7%B2%E5%90%AF%E7%94%A8%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E5%88%97%E8%A1%A8%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015.3333px%3B%22%3EDPMAC1%40xgmii%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%2C%20DPMAC2%40xgmii%2C%20DPMAC3%40xgmii%2C%20DPMAC4%40xgmii%2C%20DPMAC5%40xgmii%2C%20DPMAC6%40xgmii%2C%20DPMAC7%40xgmii%2C%20DPMAC8%40xgmii%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%B0%86%E6%9C%8D%E5%8A%A1%E5%99%A8%20IP%20%E5%9C%B0%E5%9D%80%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%82%A8%E5%B7%B2%E9%85%8D%E7%BD%AE%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E4%B8%BB%E6%9C%BA%E7%9A%84%20IP%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20serverip%20%3CIPADDRESS1%3E%3C%2FIPADDRESS1%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%B0%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethact%3C%2FSPAN%3E%E5%92%8C%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethprime%3C%2FSPAN%3E%E8%AE%BE%E7%BD%AE%E4%B8%BA%E8%BF%9E%E6%8E%A5%E5%88%B0%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E7%9C%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211685%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22341964%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-344335%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20transparent%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3ELS2088ARDB%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E6%98%A0%E5%B0%84%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%94%A8%E4%BA%8E%E5%B0%86%E6%9C%BA%E7%AE%B1%E5%89%8D%E9%9D%A2%E6%9D%BF%E4%B8%8A%E6%98%BE%E7%A4%BA%E7%9A%84%E4%BB%A5%E5%A4%AA%E7%BD%91%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%E4%B8%8E%20U-Boot%20%E5%92%8C%20Linux%20%E4%B8%AD%E7%9A%84%E7%AB%AF%E5%8F%A3%E5%90%8D%E7%A7%B0%E8%BF%9B%E8%A1%8C%E6%98%A0%E5%B0%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Esetenv%20ethprime%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethprime%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDPMAC1%40xgmii%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethact%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%20connected%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethact%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDPMAC1%40xgmii%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011.5pt%3B%20color%3A%20%2351626f%3B%22%3E%E8%AE%BE%E7%BD%AE%E7%94%B5%E8%B7%AF%E6%9D%BF%E7%9A%84IP%E5%9C%B0%E5%9D%80%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E9%9D%99%E6%80%81IP%E5%9C%B0%E5%9D%80%EF%BC%8C%E6%88%96%E8%80%85%E5%A6%82%E6%9E%9C%E4%B8%BB%E6%9D%BF%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0DHCP%E6%9C%8D%E5%8A%A1%E5%99%A8%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Edhcp%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22margin%3A%200px%3B%22%3E%E9%9D%99%E6%80%81%20IP%20%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ipaddr%20%3CIPADDRESS2%3E%3C%2FIPADDRESS2%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20netmask%20%3CSUBNET%20mask%3D%22%22%3E%3C%2FSUBNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200px%3B%22%3E%E5%8A%A8%E6%80%81%20IP%20%E5%9C%B0%E5%9D%80%E5%88%86%E9%85%8D%EF%BC%9A%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E4%BF%9D%E5%AD%98%E8%AE%BE%E7%BD%AE%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Esaveenv%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E6%A3%80%E6%9F%A5%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8E%20TFTP%20%E6%9C%8D%E5%8A%A1%E5%99%A8%E4%B9%8B%E9%97%B4%E7%9A%84%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ping%20%24serverip%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EDPMAC1%40xgmii%3C%2FSPAN%3E%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9C%BA%20192.168.1.1%20%E6%98%AF%E6%B4%BB%E8%B7%83%E7%9A%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1315436889%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId-1315436889%22%20id%3D%22toc-hId--2056934698%22%3E%E4%BB%8ETFTP%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%8A%A0%E8%BD%BDTF-A%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%3C%2FH3%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E6%9C%89%E5%85%B3%20TF-A%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E9%97%AA%E5%AD%98%E6%98%A0%E5%83%8F%E5%B8%83%E5%B1%80%E7%9A%84%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342651%22%20target%3D%22_blank%22%3ETF-A%20%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E7%9A%84%20LSDK%20%E5%86%85%E5%AD%98%E5%B8%83%E5%B1%80%3C%2FA%3E%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3COL%20style%3D%22border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%B0%86%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%E5%88%B7%E5%85%A5%20NOR%20%E7%BB%84%204%EF%BC%88%E4%BB%8E%20NOR%20%E7%BB%84%200%20%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%89%E3%80%82%3C%2FP%3E%3CUL%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20color%3A%20%233d3d3d%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%22%3Etftp%2082000000%20bl2_nor.pbl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%20none%20windowtext%201.0pt%3B%20padding%3A%200in%3B%20color%3A%20%233d3d3d%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%93%A6%E9%99%A4%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E0x584000000%3C%2FSPAN%3E%20%2B%24filesize%3Bcp.b%2082000000%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E0x584000000%3C%2FSPAN%3E%20%24filesize%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E5%B0%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%E9%97%AA%E5%AD%98%E5%88%B0%20NOR%20bank%204%20%3CSPAN%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%E5%90%AF%E5%8A%A8%E5%90%8E%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%9D%A5%E8%87%AA%20NOR%20%E9%93%B6%E8%A1%8C%200)%E3%80%82%3C%2FSPAN%3E%3CUL%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2011pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20tftp%2082000000%20fip.bin%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%93%A6%E9%99%A4%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E0x584100000%3C%2FSPAN%3E%20%2B%24filesize%3Bcp.b%2082000000%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E0x584100000%3C%2FSPAN%3E%20%24filesize%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%3E%E4%BB%8E%20NOR%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3Ebank%204%3C%2FSPAN%3E%E5%90%AF%E5%8A%A8%3CSPAN%3E%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20qixis_%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Ereset%20altbank%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20margin%3A%200px%3B%22%3ELS2088ARDB%20%E5%B0%86%E4%BD%BF%E7%94%A8%20TF-A%20%E5%90%AF%E5%8A%A8%E3%80%82%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%A5%E5%BF%97%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ENOTICE%3A%20UDIMM%2018ASF1G72AZ-2G3B1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ENOTICE%3A%2016%20GB%20DDR4%2C%2064-bit%2C%20CL%3D13%2C%20ECC%20on%2C%20256B%2C%20CS0%2BCS1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ENOTICE%3A%20UDIMM%2018ASF1G72AZ-2G3B1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9A4%20GB%20DDR4%EF%BC%8C32%20%E4%BD%8D%EF%BC%8CCL%3D11%EF%BC%8CECC%20%E5%BC%80%E5%90%AF%EF%BC%8CCS0%2BCS1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9ABL2%EF%BC%9Av1.5%EF%BC%88%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%9ALSDK-19.09%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E9%80%9A%E7%9F%A5%EF%BC%9ABL2%EF%BC%9A%E5%BB%BA%E9%80%A0%E6%97%B6%E9%97%B4%EF%BC%9A2019%E5%B9%B411%E6%9C%884%E6%97%A5%2016%3A04%3A08%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%B3%A8%E6%84%8F%EF%BC%9ABL31%EF%BC%9Av1.5%EF%BC%88%E5%8F%91%E5%B8%83%EF%BC%89%EF%BC%9ALSDK-19.09%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E9%80%9A%E7%9F%A5%EF%BC%9ABL31%EF%BC%9A%E5%BB%BA%E9%80%A0%E6%97%B6%E9%97%B4%EF%BC%9A2019%E5%B9%B411%E6%9C%884%E6%97%A5%2016%3A40%3A39%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E9%80%9A%E7%9F%A5%EF%BC%9A%E6%AC%A2%E8%BF%8E%E6%9D%A5%E5%88%B0%20LS2088%20BL31%20%E9%98%B6%E6%AE%B5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EU-Boot%202019.04%EF%BC%882019%E5%B9%B411%E6%9C%884%E6%97%A5%20-%2015%3A57%3A49%20%2B0530%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESoC%EF%BC%9ALS2088AE%20Rev1.1%EF%BC%880x87090011%EF%BC%89%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ECPU0(A72)%3A1800%20MHz%20CPU1(A72)%3A1800%20MHz%20CPU2(A72)%3A1800%20MHz%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ECPU3(A72)%3A1800%20MHz%20CPU4(A72)%3A1800%20MHz%20CPU5(A72)%3A1800%20MHz%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ECPU6(A72)%3A1800%20MHz%20CPU7(A72)%3A1800%20MHz%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%80%BB%E7%BA%BF%EF%BC%9A700%20MHz%20DDR%EF%BC%9A1866.667%20MT%2Fs%20DP-DDR%EF%BC%9A1600%20MT%2Fs%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E5%A4%8D%E4%BD%8D%E9%85%8D%E7%BD%AE%E5%AD%97%EF%BC%88RCW%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000000%3A%20483038b8%2048480048%2000000000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000010%3A%2000000000%2000000000%2000a00000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000020%3A%2001e01180%2000002581%2000000000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000030%3A%2000400c0b%2000000000%2000000000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000040%3A%2000000000%2000000000%2000000000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000050%3A%2000000000%2000000000%2000000000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000060%3A%2000000000%2000000000%2000027000%2000000000%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00000070%3A%20412a0000%2000040000%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E5%9E%8B%E5%8F%B7%EF%BC%9AFreescale%20Layerscape%202080a%20RDB%20Board%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E4%B8%BB%E6%9D%BF%EF%BC%9ALS2088AE%20Rev1.1-RDB%EF%BC%8C%E4%B8%BB%E6%9D%BF%E6%9E%B6%E6%9E%84%EF%BC%9AV1%EF%BC%8C%E4%B8%BB%E6%9D%BF%E7%89%88%E6%9C%AC%EF%BC%9AF%EF%BC%8C%E4%BB%8E%20vBank%20%E5%90%AF%E5%8A%A8%EF%BC%9A4%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E.......%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId-1304933785%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId-1304933785%22%20id%3D%22toc-hId--2067437802%22%3E%E9%80%89%E9%A1%B9%E4%BA%8C%EF%BC%9A%E4%BB%8E%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%EF%BC%88SD%20%E5%8D%A1%E3%80%81USB%20%E8%AE%BE%E5%A4%87%E6%88%96%20SATA%20%E7%A1%AC%E7%9B%98%EF%BC%89%E7%9A%84%E5%88%86%E5%8C%BA%E5%8A%A0%E8%BD%BD%E5%9B%BE%E5%83%8F%3C%2FH2%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E9%80%89%E6%8B%A9%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FSPAN%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20rescan%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20%E4%BF%A1%E6%81%AF%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20start%3C%2FSPAN%3E%0A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20scan%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20info%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%8F%AF%E9%80%89%20%E2%80%93%20%E5%88%97%E5%87%BA%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%9A%84%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%200%3A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E6%88%96%E8%80%85%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%20ls%20%E5%91%BD%E4%BB%A4%E8%BF%90%E8%A1%8C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%AF%B7%E5%9C%A8%20U-Boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E4%B8%8B%E8%BE%93%E5%85%A5%20ls%EF%BC%8C%E6%A3%80%E6%9F%A5%20NOR%20bank%200%20%E4%B8%AD%E7%9A%84%20U-Boot%20%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E8%AF%A5%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%3C%2FSPAN%3E%0Als%20-%20%E5%88%97%E5%87%BA%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%88%E9%BB%98%E8%AE%A4%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%A8%E6%B3%95%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20ls%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%E7%9B%AE%E5%BD%95%5D%5D%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20-%20%E5%88%97%E5%87%BA%E8%AE%BE%E5%A4%87%E7%B1%BB%E5%9E%8B%20%5Binterface%5D%20%E5%92%8C%E5%AE%9E%E4%BE%8B%20%5Bdev%5D%20%E4%B8%8A%E5%88%86%E5%8C%BA%20%5Bpart%5D%20%E7%9A%84%E7%9B%AE%E5%BD%95%20%5Bdirectory%5D%20%E4%B8%AD%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%20U-Boot%20%E4%B8%8D%E6%94%AF%E6%8C%81%E6%AD%A4%E5%91%BD%E4%BB%A4%EF%BC%8C%E5%88%99%E6%9B%B4%E6%96%B0%20NOR%20bank%200%20%E4%B8%AD%E7%9A%84%E5%A4%8D%E5%90%88%E5%9B%BA%E4%BB%B6%E6%98%A0%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E5%85%B3%E6%9B%B4%E6%96%B0%20NOR%20%E5%BA%93%E4%B8%AD%E7%9A%84%E5%A4%8D%E5%90%88%E5%9B%BA%E4%BB%B6%E6%98%A0%E5%83%8F%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fsoftware%2Fembedded-software%2Flinux-software-and-development-tools%2Flayerscape-software-development-kit-v19.09%3ALAYERSCAPE-SDK%3Ftab%3DDocumentation_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20text-decoration%3A%20underline%3B%20font-size%3A%2014px%3B%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%3CSTRONG%3ELayerscape%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%E7%94%A8%E6%88%B7%E6%8C%87%E5%8D%97%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FA%3E%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%20LSDK%20flex-installer%20%E5%91%BD%E4%BB%A4%E6%A0%BC%E5%BC%8F%E5%8C%96%2F%E5%88%9B%E5%BB%BA%20SD%20%E5%8D%A1%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E5%8A%A0%E8%BD%BD%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%3CADDR%3E%20%5B%3CFILENAME%3E%20%5B%E5%AD%97%E8%8A%82%E6%95%B0%20%5B%E4%BD%8D%E7%BD%AE%5D%5D%5D%5D%5D%3C%2FFILENAME%3E%3C%2FADDR%3E%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E5%8A%A0%E8%BD%BD%20mmc%200%3A2%20%24load_addr%20%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%E5%A6%82%E6%9E%9C%20SD%20%E5%8D%A1%E6%98%AF%E5%9C%A8%20Windows%20PC%20%E4%B8%8A%E6%A0%BC%E5%BC%8F%E5%8C%96%2F%E5%88%9B%E5%BB%BA%E7%9A%84%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20fatload%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%3CADDR%3E%20%5B%3CFILENAME%3E%20%5B%E5%AD%97%E8%8A%82%E6%95%B0%20%5B%E4%BD%8D%E7%BD%AE%5D%5D%5D%5D%5D%3C%2FFILENAME%3E%3C%2FADDR%3E%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E8%83%96%E5%8A%A0%E8%BD%BD%20mmc%200%3A2%20%24load_addr%20%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%E5%A6%82%E6%9E%9C%20SD%20%E5%8D%A1%E6%98%AF%E5%9C%A8%20Linux%20PC%20%E4%B8%8A%E6%A0%BC%E5%BC%8F%E5%8C%96%2F%E5%88%9B%E5%BB%BA%E7%9A%84%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ext2load%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5B%3CADDR%3E%20%5B%3CFILENAME%3E%20%5B%E5%AD%97%E8%8A%82%E6%95%B0%20%5B%E4%BD%8D%E7%BD%AE%5D%5D%5D%5D%5D%3C%2FFILENAME%3E%3C%2FADDR%3E%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%20%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3Bext2load%20mmc%200%3A2%20%24load_addr%20%3CSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%E8%BF%98%E8%A6%81%E6%B3%A8%E6%84%8F%EF%BC%8CLSDK%20flex-installer%20%E5%91%BD%E4%BB%A4%E5%B0%86%E5%9B%BE%E5%83%8F%E6%94%BE%E5%9C%A8%20IInd%20%E5%88%86%E5%8C%BA%E4%B8%8A%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%9C%A8%E5%8A%A0%E8%BD%BD%E5%91%BD%E4%BB%A4%E4%B8%AD%E4%BD%BF%E7%94%A8%200%3A2%E3%80%82%E5%A6%82%E6%9E%9C%20SD%20%E5%8D%A1%E5%9C%A8%20Windows%20PC%20%E6%88%96%20Linux%20PC%20%E4%B8%8A%E4%BB%85%E6%A0%BC%E5%BC%8F%E5%8C%96%E4%B8%BA%E5%8D%95%E4%B8%AA%E5%88%86%E5%8C%BA%EF%BC%8C%E5%88%99%E5%9C%A8%20fatload%2Fext2load%20%E5%91%BD%E4%BB%A4%E4%B8%AD%E5%BA%94%E4%BD%BF%E7%94%A8%200%20%E8%80%8C%E4%B8%8D%E6%98%AF%200%3A2%E3%80%82%3C%2FP%3E%20%20%20%20%20%20%26nbsp%3B%26nbsp%3B%20%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BB%8E%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E5%8A%A0%E8%BD%BD%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%E5%9B%BE%E5%83%8F%3C%2FSPAN%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3Bbl2_nor.pbl%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3D14379%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20usb%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3E%E5%B0%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ebl2_nor.pbl%3C%2FSPAN%3E%E7%BC%96%E7%A8%8B%E5%88%B0%20NOR%20bank%204%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E5%90%AF%E5%8A%A8%E5%90%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%9D%A5%E8%87%AA%20NOR%20%E7%BB%84%200)%3C%2FSPAN%3E%20%3A%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E6%93%A6%E9%99%A4%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E0x584000000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%2B%24filesize%3Bcp.b%200xa0000000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E0x584000000%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%24filesize%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%8A%A0%E8%BD%BD%3CSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%E6%9D%A5%E8%87%AA%E5%AD%98%E5%82%A8%E8%AE%BE%E5%A4%87%E7%9A%84%E5%9B%BE%E5%83%8F%3C%2FSPAN%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A2%200xa0000000%26nbsp%3Bfip.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3D131510%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20usb%200%3A2%200xa0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%200%3A2%200xa0000000%26nbsp%3B%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%89%93%E5%8D%B0%E6%96%87%E4%BB%B6%E5%A4%A7%E5%B0%8F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E5%B0%86%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efip.bin%3C%2FSPAN%3E%E7%83%A7%E5%86%99%E5%88%B0%20NOR%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E7%BB%84%204%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E5%90%AF%E5%8A%A8%E5%90%8E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E6%9D%A5%E8%87%AA%20NOR%20%E7%BB%84%200)%3C%2FSPAN%3E%20%3A%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E6%93%A6%E9%99%A4%200x584100000%20%2B%24filesize%3Bcp.b%200xa0000000%200x584100000%20%24filesize%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%E4%BB%8E%20NOR%20bank%204%20%E5%90%AF%E5%8A%A8%EF%BC%9A%20%3CSPAN%20style%3D%22border%3A%200px%3B%20background-color%3A%20%23ffffff%3B%20font-weight%3A%20inherit%3B%20background%3A%20white%3B%20font-size%3A%2015px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20qixis_%20%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015px%3B%22%3Ereset%20altbank%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3ELS2088ARDB%20%E5%B0%86%E4%BD%BF%E7%94%A8%20TF-A%20%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1118514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E8%AE%BE%E5%A4%87%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎09-10-2020 02:40 AM
更新人:
