LS1046ARDB - How to update DPAA1 FMan microcode (ucode) image in QSPI NOR flash
Follow these steps to update the DPAA1 FMan ucode image in QSPI NOR flash.
cpld reset boots the board from QSPI NOR flash0 and cpld reset altbank boots the board from the QSPI NOR flash1.
sf probe 0:1 means that the alternate bank will be written to. So, if the board boots from QSPI NOR flash0 and sf probe 0:1 is entered at the U-Boot prompt, the commands that follow will program QSPI NOR flash1.
Obtaining DPAA1 FMan ucode image
Clone the qoriq-fm-ucode repository.
  1. $ git clone https://github.com/NXP/qoriq-fm-ucode.git
  2. $ cd qoriq-fm-ucode
  3. $ git checkout LSDK-<LSDK version>. For example, $ git checkout LSDK-18.12
The prebuilt FMan ucode images, fsl_fman_ucode_ls1046_r1.0_<microcode version>.bin, are at qoriq-fm-ucode/. In the binary file, ls1046_r1.0 refers to the LS1046A silicon revision 1.0. See qoriq-fm-ucode/readme for a description of the ucode version numbers.
Programming FMan ucode image to QSPI NOR flash
FMan ucode image can be loaded to LS1046ARDB from a TFTP server or from a mass storage device (SD, USB, or SATA).
Option 1: Load image from the TFTP server
  1. Boot LS1046ARDB from QSPI NOR flash. Ensure that the switches are set to boot the board from QSPI. For booting from QSPI, SW5[1:8] = 00100010
  2. Boot from QSPI NOR flash0: => cpld reset
    In boot log, you’ll see:
    Board: LS1046ARDB, boot from QSPI vBank 0
Set up Ethernet connection
When board boots up, U-Boot prints a list of enabled Ethernet interfaces.
FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@TGEC1, FM1@TGEC2
  1. Set server IP to the IP of the host machine on which you have configured the TFTP server.
    => setenv serverip <ipaddress1>
  2. Set ethact and ethprime as the Ethernet interface connected to the TFTP server.
    See LS1046ARDB Ethernet port mapping for the mapping of Ethernet port names appearing on the chassis front panel with the port names in U-Boot and Linux.
    => setenv ethprime <name of interface connected to TFTP server>
    For example:
    => setenv ethprime FM1@DTSEC4
    => setenv ethact <name of interface connected to TFTP server>
    For example:
    => setenv ethact FM1@DTSEC4
  3. Set IP address of the board. You can set a static IP address or, if the board can connect to a dhcp server, you can use the dhcp command.
    Static IP address assignment:
    => setenv ipaddr <ipaddress2>
    => setenv netmask <subnet mask>
    Dynamic IP address assignment:
    => dhcp
  4. Save the settings.
    => saveenv
  5. Check the connection between the board and the TFTP server.
=> ping $serverip
Using FM1@DTSEC4 device
host 192.168.1.1 is alive
Load FMan ucode image from the TFTP server
  1. Program QSPI NOR flash1: => sf probe 0:1
  2. Flash the FMan ucode image:
    1. => tftp 0x80000000 <path to FMan ucode>/fsl_fman_ucode_ls1046_r1.0_<ucode version>.bin
    2. => print filesize
      filesize=7f5c
  3. Program the FMan ucode image to QSPI NOR flash: => sf erase 0x900000 +$filesize && sf write 0x80000000 0x900000 $filesize
    Address  0x900000 is the location of the FMan ucode image in QSPI NOR flash.  Refer Flash layout for new boot flow with TF-A for the complete flash memory layout.
  4. Boot from QSPI NOR flash1 and press Enter to stop the autoboot: => cpld reset altbank
    Board: LS1046ARDB, boot from QSPI vBank 4
    You can check the following code line in the boot log to confirm that the DPAA1 FMan ucode image in QSPI NOR flash is updated.
    Fman1: Uploading microcode version 106.4.18
  5. Ensure that SD card, USB flash drive, or SCSI hard disk installed with LSDK Ubuntu distribution is plugged into the board to boot the board to Ubuntu.
    Ubuntu 18.04.1 LTS localhost ttyS0
    localhost login: root
    Password:
    Last login: Sun Jan 28 16:05:12 UTC 2018 on ttyS0
    Welcome to Ubuntu 18.04.1 LTS (GNU/Linux 4.9.105 aarch64)
    * Documentation: https://help.ubuntu.com
    * Management: https://landscape.canonical.com
    * Support: https://ubuntu.com/advantage
    If U-Boot does not find LSDK on a mass storage device, it will boot TinyDistro from lsdk_linux_arm64_ tiny.itb stored in QSPI NOR flash.
Option 2: Load image from partition on mass storage device (SD, USB, or SATA)
  1. Boot LS1046ARDB from QSPI NOR flash. Ensure that the switches are set to boot the board from QSPI. For booting from QSPI , SW5[1:8] = 00100010
  3. Select mass storage device to use.
    => mmc rescan
    => mmc info
    Or
    => usb start
    => usb info
    Or
    => scsi scan
    => scsi info
  4. Optional – List files on storage device
    => ls mmc <device:partition>
    For example:
    => ls mmc 0:3
    System Volume Information/
    32604 fsl_fman_ucode_ls1046_r1.0_106_4_18.bin
    1 file(s), 1 dir(s)
    Or
    => ls usb <device:partition>
    For example:
    => ls usb 0:1
    Or
    => ls scsi <device:partition>
    For example:
    => ls scsi 0:2
    If the ls command fails to run, check that U-Boot in QSPI NOR flash0 supports the command by typing ls at the U-Boot prompt:
    => ls ls - lists files in a directory (default)
    Usage: ls <interface> [<dev[:part]> [directory]]
    - Lists files in directory [directory] of partition [part] on device type [interface] and instance [dev].
    If U-Boot does not support this command, then update the composite firmware image in QSPI NOR flash0.
    For steps to update composite firmware image in QSPI NOR flash, see LS1046ARDB - How to update composite firmware image in QSPI NOR flash.
  5. Program QSPI NOR flash1: => sf probe 0:1
  6. Load FMan ucode image from the storage device.
    => load mmc <device:partition> 80000000 <image name>
    => print filesize
    For example:
    => load mmc 0:3 80000000 fsl_fman_ucode_ls1046_r1.0_106_4_18.bin
    32604 bytes read in 18 ms (1.7 MiB/s)
    => print filesize
    filesize=7f5c
    Or
    => load usb <device:partition> 80000000 <image name>
    => print filesize
    Or
    => load scsi <device:partition> 80000000 <image name>
    => print filesize
  7. Program the FMan ucode image to QSPI NOR flash: => sf erase 0x900000 +$filesize && sf write 0x80000000 0x900000 $filesize
  8. Boot from QSPI NOR flash1 and press Enter to stop the autoboot: => cpld reset altbank
  9. Ensure that SD card, USB flash drive, or SCSI hard disk installed with LSDK Ubuntu distribution is plugged into the board to boot the board to Ubuntu.
    Password:
%3CLINGO-SUB%20id%3D%22lingo-sub-1124649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEDPAA1%20FMan%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88ucode%EF%BC%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEDPAA1%20FMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%3C%2FSPAN%3E%E3%81%AFQSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%20altbank%3C%2FSPAN%3E%E3%81%AFQSPI%20NOR%20flash1%E3%81%8B%E3%82%89%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%E3%81%AF%E4%BB%A3%E6%9B%BF%E3%83%90%E3%83%B3%E3%82%AF%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8CQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81U-Boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AB%E7%B6%9A%E3%81%8F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AFQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CH1%20id%3D%22toc-hId-382457080%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2026px%3B%22%20id%3D%22toc-hId-382457080%22%20id%3D%22toc-hId-1303143155%22%3EDPAA1%20FMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E5%8F%96%E5%BE%97%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqoriq-fm-ucode%3C%2FSPAN%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E3%82%AF%E3%83%AD%E3%83%BC%E3%83%B3%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%24%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Egit%20clone%26nbsp%3B%3CA%20class%3D%22unlinked%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FNXP%2Fqoriq-fm-ucode.git%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%24%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecd%20qoriq-fm-ucode%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.2em%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%24%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3E%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3Egit%20checkout%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%22%3ELSDK-%3CLSDK%20version%3D%22%22%3E%3C%2FLSDK%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%22%3E%E4%BE%8B%E3%81%88%E3%81%B0%3C%2FSPAN%3E%E2%80%AF%24%E2%80%AF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%20lang%3D%22EN-US%22%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2011.5pt%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20class%3D%22%22%20style%3D%22background-color%3A%20inherit%3B%20margin%3A%200px%3B%22%3Egit%20checkout%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3ELSDK-18.12%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CSPAN%3E%E4%BA%8B%E5%89%8D%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%9FFMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Efsl_fman_ucode_ls1046_r1.0_.bin%3CMICROCODE%20version%3D%22%22%3E%3C%2FMICROCODE%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%81%AF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eqoriq-fm-ucode%2F%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els1046_r1.0%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%AFLS1046A%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%83%BB%E3%83%AA%E3%83%93%E3%82%B8%E3%83%A7%E3%83%B31.0%E3%82%92%E6%8C%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eucode%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E7%95%AA%E5%8F%B7%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3Eqoriq-fm-ucode%2Freadme%3C%2FSPAN%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20id%3D%22toc-hId--1424997383%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2026px%3B%22%20id%3D%22toc-hId--1424997383%22%20id%3D%22toc-hId--504311308%22%3EFMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EFMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%E3%81%AF%E3%80%81TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88SD%E3%80%81USB%E3%81%BE%E3%81%9F%E3%81%AFSATA%EF%BC%89%E3%81%8B%E3%82%89LS1046ARDB%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CH2%20id%3D%22toc-hId--734435909%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2022px%3B%22%20id%3D%22toc-hId--734435909%22%20id%3D%22toc-hId-186250166%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%EF%BC%9ATFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3C%2FH2%3E%3COL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89LS1046ARDB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8CQSPI%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3EQSPI%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AF%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%5B1%3A8%5D%20%3D%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E00100010%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3EQSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20cpld%20reset%3C%2FSPAN%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%200%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId--43874435%22%20style%3D%22color%3A%20%23646464%3B%20border%3A%200px%3B%20font-weight%3A%20600%3B%20font-size%3A%2018px%3B%22%20id%3D%22toc-hId--43874435%22%20id%3D%22toc-hId-876811640%22%3E%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E6%8E%A5%E7%B6%9A%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3C%2FH3%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81U-Boot%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFM1%40DTSEC3%20%5BPRIME%5D%E3%80%81FM1%40DTSEC4%E3%80%81FM1%40DTSEC5%E3%80%81FM1%40DTSEC6%E3%80%81FM1%40TGEC1%E3%80%81FM1%40TGEC2%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AEIP%E3%82%92%E3%80%81TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEIP%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20serverip%20%3CIPADDRESS1%3E%3C%2FIPADDRESS1%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethact%3C%2FSPAN%3E%E3%81%A8%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eethprime%3C%2FSPAN%3E%E3%82%92TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%E3%82%B7%E3%83%A3%E3%83%BC%E3%82%B7%E3%81%AE%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%E3%83%BB%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E5%90%8D%E3%81%A8U-Boot%E3%81%8A%E3%82%88%E3%81%B3Linux%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%E5%90%8D%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20_jive_internal%3D%22true%22%20data-containerid%3D%2211685%22%20data-containertype%3D%2214%22%20data-content-finding%3D%22Community%22%20data-objectid%3D%22342200%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342200%22%20style%3D%22color%3A%20%233d9ce7%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%201px%200px%201px%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3ELS1046ARDB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E3%83%BB%E3%83%9D%E3%83%BC%E3%83%88%E3%83%BB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%3C%2FA%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2015.3333px%3B%22%3Esetenv%20ethprime%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethprime%20FM1%40DTSEC4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ethact%20%3CNAME%20of%3D%22%22%20interface%3D%22%22%20connected%3D%22%22%3E%3C%2FNAME%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bsetenv%20ethact%20FM1%40DTSEC4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AEIP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8Cdhcp%E3%82%B5%E3%83%BC%E3%83%90%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Edhcp%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3C%2FSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E9%9D%99%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20ipaddr%20%3CIPADDRESS2%3E%3C%2FIPADDRESS2%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20setenv%20netmask%20%3CSUBNET%20mask%3D%22%22%3E%3C%2FSUBNET%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E5%8B%95%E7%9A%84IP%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20dhcp%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CP%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3B%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3Esaveenv%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8TFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E9%96%93%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ping%20%24serverip%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EUsing%26nbsp%3B%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EFM1%40DTSEC4%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3Edevice%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20margin%3A%200in%200in%200.0001pt%200.25in%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ehost%20192.168.1.1%20is%20alive%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1851328898%22%20id%3D%22toc-hId--1851328898%22%20id%3D%22toc-hId--930642823%22%3ETFTP%E3%82%B5%E3%83%BC%E3%83%90%E3%81%8B%E3%82%89FMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FH3%3E%3COL%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20probe%200%3A1%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3EFMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3COL%20style%3D%22list-style-type%3A%20lower-alpha%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20tftp%200x80000000%20%3CPATH%20to%3D%22%22%20fman%3D%22%22%20ucode%3D%22%22%3E%2Ffsl_fman_ucode_ls1046_r1.0_%3CUCODE%3E.bin%3C%2FUCODE%3E%3C%2FPATH%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bprint%20filesize%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%3D7f5c%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3EFMan%20ucode%3C%2FSPAN%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FSPAN%3E%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Eerase%200x900000%20%2B%24filesize%20%26amp%3B%26amp%3B%20sf%20write%200x80000000%200x900000%20%24filesize%3C%2FSPAN%3E%3CP%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E0x900000%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%81%AFQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AB%E3%81%82%E3%82%8B%3CSPAN%3EFMan%20ucode%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342651%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3ETF-A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81Enter%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3D%26gt%3B%20%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%20altbank%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%AD%E3%82%B0%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E8%A1%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEDPAA1%20FMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFman1%3A%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3106.4.18%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92Ubuntu%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81LSDK%20Ubuntu%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FSD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%80%81USB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFSCSI%E3%83%8F%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3Ecpld%20reset%26nbsp%3Baltbank%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%233d3d3d%3B%20margin%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EUbuntu%2018.04.1%20LTS%20localhost%20ttyS0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elocalhost%20login%3A%20root%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EPassword%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ELast%20login%3A%20Sun%20Jan%2028%2016%3A05%3A12%20UTC%202018%20on%20ttyS0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EWelcome%20to%20Ubuntu%2018.04.1%20LTS%20(GNU%2FLinux%204.9.105%20aarch64)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E*%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%88%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fhelp.ubuntu.com%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%20padding-right%3A%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fhelp.ubuntu.com%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E*%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Flandscape.canonical.com%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%20padding-right%3A%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flandscape.canonical.com%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E*%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fubuntu.com%2Fadvantage%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fubuntu.com%2Fadvantage%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EU-Boot%E3%81%8C%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%A7LSDK%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81FlexSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_tiny.itb%3C%2FSPAN%3E%E3%81%8B%E3%82%89TinyDistro%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CH2%20id%3D%22toc-hId--1861832002%22%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20bold%3B%20font-size%3A%2020px%3B%22%20id%3D%22toc-hId--1861832002%22%20id%3D%22toc-hId--941145927%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%EF%BC%9A%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%EF%BC%88SD%E3%80%81USB%E3%81%BE%E3%81%9F%E3%81%AF%20SATA%EF%BC%89%E4%B8%8A%E3%81%AE%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FH2%3E%3COL%20style%3D%22padding%3A%200px%200px%200px%2030px%3B%22%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89LS1046ARDB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8CQSPI%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011pt%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3EQSPI%3C%2FSPAN%3E%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AF%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-size%3A%2015px%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ESW5%5B1%3A8%5D%20%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2000100010%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22margin%3A%200.2em%200px%3B%22%3EQSPI%20NOR%20flash0%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%26nbsp%3Bcpld%20reset%3C%2FSPAN%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%200%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20rescan%3C%2FSPAN%3E%3C%2FPRE%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20mmc%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20start%3C%2FSPAN%3E%0A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20usb%20info%3C%2FSPAN%3E%3C%2FPRE%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20scan%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20scsi%20info%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BB%BB%E6%84%8F%20%E2%80%93%20%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20mmc%200%3A3%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%20System%20Volume%20Information%2F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%2032604%20fsl_fman_ucode_ls1046_r1.0_106_4_18.bin%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E1%20file(s)%2C%201%20dir(s)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20usb%200%3A1%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%20%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%20scsi%200%3A2%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22info%22%20__jive_macro_name%3D%22alert%22%20alert%3D%22info%22%20class%3D%22jive_text_macro%20jive_macro_alert%22%3E%3CP%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%9F%E8%A1%8C%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81QSPI%20NOR%20flash0%E5%86%85%E3%81%AEU-Boot%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81U-Boot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%A7%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20ls%3C%2FSPAN%3E%0Als%20-%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E3%81%84%E6%96%B9%EF%BC%9A%0A%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Els%20%3CINTERFACE%3E%20%5B%3CDEV%3E%20%5Bdirectory%5D%5D%3C%2FDEV%3E%3C%2FINTERFACE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E-%20%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E7%A8%AE%E9%A1%9E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Binterface%5D%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Bdev%5D%3C%2FSPAN%3E%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E5%88%86%E3%81%91%E3%82%89%E3%82%8C%E3%81%9F%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Bpart%5D%3C%2FSPAN%3E%E3%81%AE%3CSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%5Bdirectory%5D%3C%2FSPAN%3E%E5%86%85%E3%81%AB%E3%81%82%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EU-Boot%20%E3%81%8C%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A50%E5%86%85%E3%81%AE%E8%A4%87%E5%90%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AE%E8%A4%87%E5%90%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342252%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3ELS1046ARDB%20-%20QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AE%E8%A4%87%E5%90%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FPRE%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20sf%20probe%200%3A1%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89FMan%20ucode%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-size%3A%2011.5pt%3B%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B8%3C%2FSPAN%3E0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20mmc%200%3A3%2080000000%26nbsp%3B%3CSPAN%3Efsl_fman_ucode_ls1046_r1.0_106_4_18.bin%3C%2FSPAN%3E%3CBR%20%2F%3E32604%20bytes%20read%20in%2018%20ms%20(1.7%20MiB%2Fs)%3CBR%20%2F%3E%3D%26gt%3B%20print%20filesize%3CBR%20%2F%3Efilesize%3D7f5c%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20usb%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B8%3C%2FSPAN%3E0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%81%AF%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20load%20scsi%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CPARTITION%3E%3C%2FPARTITION%3E%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B8%3C%2FSPAN%3E0000000%20%3CIMAGE%20name%3D%22%22%3E%3C%2FIMAGE%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200px%200px%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3D%26gt%3B%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E8%A1%A8%E7%A4%BA%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%ABFMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3D%26gt%3B%3CSPAN%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Esf%20erase%200x900000%20%2B%24filesize%20%26amp%3B%26amp%3B%20sf%20write%200x80000000%200x900000%20%24filesize%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E0x900000%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%81%AFQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AB%E3%81%82%E3%82%8B%3CSPAN%3EFMan%20ucode%3C%2FSPAN%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FSPAN%3E%3CSPAN%3E%3C%2FSPAN%3E%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-342651%22%20style%3D%22text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3C%2FSPAN%3E%3CSPAN%20lang%3D%22EN-US%22%3ETF-A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E6%96%B0%E3%81%97%E3%81%84%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20lang%3D%22EN-US%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EQSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A51%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81Enter%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E8%87%AA%E5%8B%95%E8%B5%B7%E5%8B%95%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%99%EF%BC%9A%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%26nbsp%3Baltbank%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EBoard%3A%20LS1046ARDB%2C%20boot%20from%20QSPI%20vBank%204%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%BB%E3%83%AD%E3%82%B0%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E8%A1%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81QSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%86%85%E3%81%AEDPAA1%20FMan%20ucode%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20padding%3A%200px%200px%200px%2030px%3B%22%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EFman1%3A%20%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3106.4.18%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E4%B8%AD%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%20margin%3A%200.5ex%200px%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92Ubuntu%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81LSDK%20Ubuntu%E3%83%87%E3%82%A3%E3%82%B9%E3%83%88%E3%83%AA%E3%83%93%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9FSD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%80%81USB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFSCSI%E3%83%8F%E3%83%BC%E3%83%89%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3D%26gt%3B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Ecpld%20reset%26nbsp%3Baltbank%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EUbuntu%2018.04.1%20LTS%20localhost%20ttyS0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elocalhost%20login%3A%20root%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EPassword%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3ELast%20login%3A%20Sun%20Jan%2028%2016%3A05%3A12%20UTC%202018%20on%20ttyS0%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3EWelcome%20to%20Ubuntu%2018.04.1%20LTS%20(GNU%2FLinux%204.9.105%20aarch64)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E*%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%88%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fhelp.ubuntu.com%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%20padding-right%3A%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fhelp.ubuntu.com%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E%3CSPAN%3E*%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%EF%BC%9A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Flandscape.canonical.com%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%20padding-right%3A%20calc(12px%20%2B%200.35ex)%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Flandscape.canonical.com%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3E*%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3A%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fubuntu.com%2Fadvantage%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20style%3D%22color%3A%20%232989c5%3B%20text-decoration%3A%20none%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fubuntu.com%2Fadvantage%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EU-Boot%E3%81%8C%E5%A4%A7%E5%AE%B9%E9%87%8F%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%A7LSDK%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81FlexSPI%20NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%3CSPAN%20style%3D%22font-family%3A%20'courier%20new'%2C%20courier%2C%20monospace%3B%22%3Elsdk_linux_arm64_tiny.itb%3C%2FSPAN%3E%E3%81%8B%E3%82%89TinyDistro%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1124649%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EQorIQ%20LS1%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:02 AM
更新者:
