Hi Sir,
I am working on NHS3100 with LPCXpresso.
I imported the project archive release_mra2_10_1_nhs3100.zip and tested the example projects such as "app_example_dp_i2c" to study I2C driver usage.
But here I met the problem that Trace_Printf doesNOT work.
It looks like the function "Trace_Printf" blocking the routine running.
I tried to disable "Trace_Printf" by adding a "return" statement in the begin of the function body as below:
void Trace_Printf(const char *format, ...)
return;
and after that, the phenomenon disappears.
Could you help to review and advice how I should do or config something to let the original project "app_example_dp_i2c" run normally?
Many thanks,
Arna
已解决! 转到解答。
1. Yes, correct.
2. Enabling will redirect the datapipe to the SWD debugger interface - provided you link in the semihosting functionality by using the Redlib (semihost) library. So, yes.
Best,
Dries.
Hi Dries Moors,
Thank you for your reply.
I read the function "Trace_Printf" again and debug by breakpoint.
It looks the default "#define TRACE_DATAPIPE_I2C0 1".
So the function call the below code snippet:
#if TRACE_DATAPIPE_I2C0 == 1
I2CIO_Tx((const uint8_t*)Trace_formattedString, stringSize);
#endif
1. As my understand, this should require a I2C peripheral to printf the message?
2. So I should undefine "TRACE_DATAPIPE_I2C0" and define "TRACE_DATAPIPE_SEMIHOSTING" to value "1" if I have no I2C device for printf pipe?
Arna
1. Yes, correct.
Best,
Dries.
Hi, Is this problem resolved at your side? Looking at the other posts, I assume it is? Keep in mind that semihosting in combination with the Deep Power Down and Power-off modes will not work: the moment you lose the SWD debug connection, any semihosting print will halt the core indefinitely.
