lpc4337 vs lpc43s37 aes encryption
824 次查看
vianneyfenart
Hello
I need help : i have questions about lpc4337 vs lpc43s37
it seems the only difference betwin both is the aes encrytion.
i need to encrypt with basic aes encryption....and i found an Application Note from NXP (AN11241) and the software library for use it.
it seems i don't need to have lpc43s37 to do that : the lpc4337 can use this library without aes peripheral i'm right?.
thanks
814 次查看
ZhangJennie
yes, AN11241 is SW lib, you can port it to LPC4337 to implement AES encryption.
But please note:
The library has been tested on the following targets: LPC11Axx (Cortex-M0 based), LPC1769 (Cortex-M3 based). For porting the library to other targets, the user may extend or modify the target definition in the cipher.h file.
For more, see AN11241.
Have a nice day,
Jun Zhang
815 次查看
ZhangJennie
But please note:
Have a nice day,
Jun Zhang
809 次查看
vianneyfenart
Hi Jun Zhang,
thanks for your answer
best regards
vianney
789 次查看
ZhangJennie
You are welcome!
