PWM CONFIGURATION IN LPC 804
823件の閲覧回数
Arularasan
HI I am trying to generate pwm in P0_24  in LPC804 Microcontroler.
If there are any changes in my configuration, update me
int main()
 SYSCON->PRESETCTRL0 |= 1 << 25;
SYSCON->SYSAHBCLKCTRL0 |= 1<<7;
SWM0->PINASSIGN.PINASSIGN4 = 0X18;  // P0_24 PIN SELECTED
SYSCON->SYSAHBCLKCTRL0 |= 0<<7;
CTIMER->TCR |= 1 << 1;
CTIMER->PR = 0x00U;
CTIMER->MCR |= 1 << 0 | 1 << 1;
CTIMER->MR[0] =100;
CTIMER->MSR[0]=100;
CTIMER->PWMC |= 0<<1;
CTIMER->TCR |= 1<<0 | 1<<1;
while(1)
CTIMER->MR[1] =50;
CTIMER->MSR[1]=50;
タグ(1)
759件の閲覧回数
Hello @Arularasan
Please first confirm the PWM demo under SDK can generate PWM signal on your board, then development based on it,
that can speeds up your development.
Alice
3 返答(返信)
807件の閲覧回数
Hello @Arularasan
What about the issue  with your project?
About PWM, strongly recommend you the PWM demo under SDK.
Download SDK from:  https://mcuxpresso.nxp.com/en/select
Alice
799件の閲覧回数
Arularasan
@Alice_Yang
The pwm pulse is not generated, please update me if there are any changes in the configuration below
int main()
* 1 */ SYSCON->SYSAHBCLKCTRL0 |=  1 << 25 ;// Enables clock for CTIMER0.
/* 2 */ SYSCON->PRESETCTRL0 |= 1 << 25; //  CTIMER reset control // Clear the CTIMER reset.
/* 3 */ // Pins: Select timer pins through switch matrix.
/* 4 */    //  SWM0->PINASSIGN_DATA[4] | ;
    SYSCON->SYSAHBCLKCTRL0 |= 1<<7; //Enables clock for switch matrix
SWM0->PINASSIGN.PINASSIGN4 = 0X18;// P0_24 PIN SELECTED
SYSCON->SYSAHBCLKCTRL0 |= 0<<7; //DISABLE clock for switch matrix
/* 5 */  CTIMER->TCR |= 1 << 1;/*Enabled. The Timer Counter and the Prescale Counter are synchronously reset on the
                                 next positive edge of the APB bus clock. The counters remain reset until TCR[1] is
                                 returned to zero*/
CTIMER->PR = 0xFFFFFFFFU;
/* 6 */ CTIMER->MCR |= 1 << 0 | 1 << 1; // Interrupt on MR0: an interrupt is generated when MR0 matches the value in the TC
                                        // Reset on MR0: the TC will be reset if MR0 matches it. 0 = disabled. 1 = enabled
/* 7 */ CTIMER->MR[0] =100;//Timer counter match value
/* 8 */ CTIMER->MSR[0]=100; //Timer counter match shadow value
           //  START COUNT
/* 9 */ CTIMER->PWMC |= 0<<1;//PWM. PWM mode is enabled for CTIMER_MAT0.
/* 10 */ CTIMER->TCR |= 1<<0 | 1<<1;// Enabled. The Timer Counter and Prescale Counter are enabled.
                                    //Enabled. The Timer Counter and the Prescale Counter are synchronously reset on the
//next positive edge of the APB bus clock. The counters remain reset until TCR[1] is
//returned to zero
 // while(1)
  /* 7 */ CTIMER->MR[1] =50;//Timer counter match value
  /* 8 */ CTIMER->MSR[1]=50; //Timer counter match shadow value
760件の閲覧回数
Hello @Arularasan
Alice
