Looking at the LPC55S6x/LPC55S2x/LPC552x User manual (Rev. 1.9 — 15 November 2019).
For each DMA channel, the dedicated DMA request sources are shown in Tables 408 and 409.
These tables are a bit confusing, for example DMA0 channel 4 shows request source
Flexcomm Interface 0 RX / I2C Slave
Assuming one is not using I2C, does this mean the DMA channel can be used for any flexcomm interface 0 RX function (ie SPI if flexcomm 0 is configured for SPI)?
Thanks!
Best Regards, Dave
PS devel@latke.net - This is in reference to this question: https://community.nxp.com/message/1291511
Any ideas? I've got a couple but not sure. NXP has been unhelpful so far unfortunately...
Dave Nadler wrote:
PS Andy Peters - This is in reference to this question: DMA for Flexcomm SPI with 20-24-bit peripherals?
Honestly, I can't help with that. I haven't delved into SPI and DMA yet (but it's on my list).
I just spent a good part of my evening yesterday trying to get a simple USART interrupt to work. Turns out that the stupid library had an override for the default handler and so it ignored my override handler. I had to comment out the override in fsl_flexcomm.c -- it's just daft and overcomplicated. I don't even know why it was using fsl_flexcomm.c.
I'm now working through using DMA with a UART -- the example code and driver are mindbendingly undocumented.
Based on the example lpcxpresso55s28_usart_dma_transfer, the DMA channels are associated with all configurations of a Flexcomm.
There are two requests for each Flexcomm: one for transmit, the other for receive. When configured to work as I2C, one of the requests is for when the Flexcomm is used as an I2C slave, and the other is used when the Flexcomm is used as an I2C master.
So for Flexcomm 0, the table lists:
DMA Channel 4: Flexcomm Interface 0 RX / I2C Slave
DMA Channel 5: Flexcomm Interface 0 TX / I2C Master
It's the same for the other Flexcomms.
There are a couple of examples that use the Flexcomm as an SPI master or slave using DMA transfers.
I'm finding the documentation very difficult, in particular the following writing mistakes:
Anybody at NXP, can you please request these document clarifications/corrections?
Thanks!
Best Regards, Dave
Hello Dave Nadler
Regarding the documentation, thank you for letting me know, I will inform your comments to the corresponding team.
I apologize for the inconvenience this is causing you, please let me help you clarifying these points to you:
Please let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
jeremyzhou - Can you clarify? You seem to be expert on DMA on these parts?
Thanks!
