Hello !
1.
Do I understand right and FLASH API is designed for be called from secure side only ?
#define BOOTLOADER_API_TREE_POINTER ((bootloader_tree_t *)0x130010f0U)
#define VERSION1_FLASH_API_TREE BOOTLOADER_API_TREE_POINTER->flashDriver.version1FlashDriver
But all FLASH API required Non secure address range e.g started from 0 ?
Does it matter what kind of attributes has erased flash sector , Secure or Not secure ?
2. When I read erased flash memory it has value 0x00, not 0xFF what is typical value ?
3. FLASH API in UM might have wrong parameters explanation:
Erase:
lengthInBytes The length, given in bytes (not words or long words) to be erased. Must be word-aligned.
Program :
lengthInBytes The length in bytes (not words or long words) to be erased; the length must also be 512bytes-aligned.
I think erasing can be done on sector 512 byte basic.
But I expect it should be possible to write by 4 byte aligned chunks. But I have HardFault if I write less than 512 bytes.
Can I program one dword ( 4 bytes ) at once ?
Eugene
Hi soledad !
I have got modified driver already and it perform basic functions.
But I should be able to write small chunk of data 4-128 bytes and looks like I can write 512 byte chunk only.
I will try to do read/modify/write operation but in your specification amount of partial writes is not specified.
E.g how many times I can write the same page before it should be erased.
And looks like erased page has value 0x00 and it is not clear if I can move bits from 0 to 1 or vise versa.
In UM mentioned that prefetch bit should be disabled while FLASH_Erase/Program operation.
But what about Verify ? Should I disable Acceleration bit as well ?
What about interrupt disabling ? Firmware executed from flash memory and may be I should disable those
and may be during verify as well ?
Eugene
Hi soledad !
can it be so that fix is need for version 2 of flash board.
But my A2 board returns version 3 :
https://community.nxp.com/thread/521240
I have added more comments to this thread.
Eugene
