DEARS,
I used LPCXpresso55S36 test i3c port,use i3c port PIN 69,PIN 55, no clock and data.please help check if the demo is OK,or please help share a project about I3C TO USB application ,thank you.
Solved! Go to Solution.
Hi @luna_liang
I downloaded SDK_2_10_2_LPCXpresso55S36, and run the i3C master_read_sensor_icm42688p example. It can work.
Please note the readme in the example.
I hope can help you.
Hang
Hi @luna_liang
Hang
麻烦给一下您邮箱,thank you。
2.10.2这个工程只有这个工程,选项里有I2C,没看到I3C module
这个是可以用吗
dear hang,
thank you,my demo has no R554,had read the read me doc,this need a short connect in R554_ PIN 2 TO PIN3,
SO can not run sussesful .
only to print: I3C master do dynamic address assignmentto the sensor slave.
Hi @luna_liang
You can download the 2.10.2 SDK by following the steps in the video.
Best regards, Alex
